Old 07-01-2012, 08:15 PM   #1
KellerMAC
KellerMAC's Avatar
Another AC Vacuum question
I am trying to find a good and strong source for the vacuum of my AC unit in my 72 C10 with factory air.
I need to run the hose from the vacuum tank under my dash to provide vacuum and was wondering which way would work best?
I have two choices - (1) use a T and tap into the main line from the valve cover and the carb (2) use a T and tap into the vacuum advance of the distributor. What is your opinion - see two pictures below.
Thanks for your help,
KellerMac
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 07-01-2012, 08:18 PM   #2
med.bronze
med.bronze's Avatar
Re: Another AC Vacuum question
use the intake manifold vacuum in the second picture
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
Old 07-01-2012, 09:40 PM   #3
KellerMAC
KellerMAC's Avatar
Thanks med.bronze - does it matter which hose off the manifold that I hook to?
Old 07-01-2012, 09:43 PM   #4
med.bronze
med.bronze's Avatar
no it shouldn't, but it might be better to put a 3-port vacuum fitting on the manifold.
1971 K-10 Custom
