Old 07-02-2012, 10:05 AM   #1
TCLARK
350 turbo
I've got a '75K5 w/350TH that Park doesn't hold on a hill..........What gives?
TCLARK is offline   Reply With Quote
Old 07-02-2012, 10:39 AM   #2
Firebirdjones
Re: 350 turbo
Sounds like the parking pawl is stripped or worn.
Firebirdjones is offline   Reply With Quote
Old 07-02-2012, 10:43 AM   #3
TCLARK
Re: 350 turbo
Thanx for the reply.........
Is this an easy fix?
Old 07-02-2012, 10:46 AM   #4
Firebirdjones
Re: 350 turbo
I'd pull the pan and have a look first. It's not a hard fix. I haven't rebuilt a 350 turbo in a while but if I remember right, you have to drop the valve body to change the parking pawl.
Could be that it's not engaging 100% or is loose too, maybe an adjustment. Might be real simple.
Old 07-02-2012, 02:21 PM   #5
TCLARK
Re: 350 turbo
I guess I will drop the pan and check it out, these old Blazers are just so heavy,it's their weak spot.
Old 07-02-2012, 03:43 PM   #6
oldgoalie
Re: 350 turbo
There is a metal piece that the park rod pushes into. The rod squeezes between it and the pawl, forcing the pawl into the park gear. Most of time the metal piece gets bent and all you have to do is replace it. Just 2 bolts once the pan is off. You can look at the pawl then. The pawl is kind of a paine to change, it pivots on a pin wich is held in with a small plug on the back side of the trans, just in front of the govenor cover. Once you get the plug out(no fun) you sometimes can get a small needle nose plyers and reach up by the pawl and slide the pin out. The fun part is the trans fluid running down your arm while you are doing all of this.
oldgoalie is offline   Reply With Quote
Old 07-02-2012, 05:18 PM   #7
Your41Plague12
Your41Plague12's Avatar
Re: 350 turbo
I second this. Also, check your shift linkage. If it's out of adjustment, it won't let it fully go into park sometimes. This is usually caused by something being worn or broken in the body mount region. Just went through it on my truck.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
