Old 07-02-2012, 10:08 AM   #1
davecarney2
davecarney2's Avatar
55-59 static drop
Can yall show some pics of static drops with the 55-59 body style. I am thinking of dropping mine with a lowered axle. Can you still do the power steering upgrade with a dropped axle?
Heres mine at stock height
Thanks,
Dave
davecarney2 is offline   Reply With Quote
Old 07-02-2012, 11:11 AM   #2
Chevette
Chevette's Avatar
Re: 55-59 static drop
I'm not using a drop axle, but I used a somewhat scientific method to determine my ride height. I put a beer can under the step, directly in front of the rear tire. If I crush the can down 25% it will fit under the bottom of the front fender ahead of the door. I'm using coilovers front and rear. I plan to use Google maps to locate speed bumps and plan my trips accordingly. As for the power steering upgrade, I have no idea. Keep in mind, you can get a 2" drop spindle for those drop axles.
Chevette is offline   Reply With Quote
Old 07-03-2012, 01:25 PM   #3
misfits1981
Trying not to hi-jack but - Chevette, are drop spindles available for the stock 55-59 axle? Any help on where they're available?
misfits1981 is offline   Reply With Quote
Old 07-03-2012, 01:40 PM   #4
davecarney2
No problem on the hi-jack I think were after the same answers
Old 07-03-2012, 03:58 PM   #5
Chevette
Chevette's Avatar
Here you go. http://www.ebay.com/itm/Forged-Two-P...sories&vxp=mtr
Old 07-03-2012, 09:37 PM   #6
Dan in Pasadena
Dan in Pasadena's Avatar
Hmmm...anyone know if these drop spindles work okay with after market disc brake conversion kits?
The other thought that occurs to me is that they may be Chinese made and are castings instead of forged pieces and may be subject to catastrophic failure(?)
Dan in Pasadena is offline   Reply With Quote
Old 07-03-2012, 10:42 PM   #7
Chevette
Chevette's Avatar
I believe they are described as "Forged Two Piece 2in Drop Spindles".
Old 07-03-2012, 10:53 PM   #8
Dan in Pasadena
aHAH! WOuld have helped if I'd READ the title of the listing, huh?
Old 07-03-2012, 11:17 PM   #9
paintman5851
this is a 55-56 panel,im asuming same frame.did a spring under with 1 inch drop blocks on the rear,now the front is a 79 camaro so its low already,nice little rake
paintman5851 is offline   Reply With Quote
Old 12-07-2012, 05:53 PM   #10
made2drag
made2drag's Avatar
ttt
made2drag is offline   Reply With Quote
Old 12-07-2012, 08:36 PM   #11
Rude Dude
Rude Dude's Avatar
Those dropped spindles are for car not truck
Rude Dude is offline   Reply With Quote
Old 12-07-2012, 09:19 PM   #12
mr48chev
mr48chev's Avatar
Beat me to it. They won't work unless you have a 55/57 car front suspension under your truck.
I've seen rumors of dropped spindles for I beam axles but haven't actually see photos of any.
A Google search for dropped spindles for I beam axles doesn't bring up any dropped spindle for any model of vehicle with an I beam axle.
My ongoing truck projects:
