Old 05-18-2003, 02:16 AM   #1
vycc
vycc's Avatar
6.2 instead of 350
what would this swap entail??? i'm want the 6.2 in my 81 GMC Sierra SWB 4X4 1/2T..... is it a bolt on or fab job from hell?? anyone who has done this throw in your 2 cents
1981 GMC Sierra 1/2 Ton SWB 4X4
vycc is offline   Reply With Quote
Old 05-18-2003, 03:14 AM   #2
1969 GMC
1969 GMC's Avatar
I've never heard of anyone swapping a diesel in place of a 350, usually the other way around. Sounds cool!
Try asking this in the engine & drivetrain board and more people will see it.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-20-2003, 02:34 AM   #3
red450ih
red450ih's Avatar
The 6.2 will bolt right in. Same bellhousing pattern, mounts, etc. You will have to run hydro boost for your brakes, Diesels make no vaccume.
Keith
GMC
red450ih is offline   Reply With Quote
Old 05-26-2003, 09:55 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
To be honest, I don't know why you would want a 6.2. It is a giant boat anchor (IMO) They really don't have much power unless you turbo them. Mine leaks oil like a dang Jimmy 2 cycle diesel and it is really loud. Plus it is hard to start and I spend a small forture heating the darn thing in the winter. Despite all that, they seem to be very expensive to buy.
On the plus side, they do get reasonable milage and they do run forever.
I have a 6.2 in my truck and was thinking about going to a 502. I think you would want to get a truck that had everything for a doner. The electrical/starter system must be a little different as it has a glowplug system and even the dash bezel has extra holes for the glowplug lights. The fuel filters are on the firewall and it has an unbelievable amount of sound dampening felt everywhere. Dual batteries, huge radiator with engine oil cooler and heavier front springs.
Sounds like a lot of work to me.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 05-27-2003, 06:34 PM   #5
vycc
vycc's Avatar
yeah the diesel was just a thought and now after so advice i'm going to put a 350 on propane, that way i don't have to beef up any suspension parts
