07-02-2012, 12:36 PM | #1 |
Blackdawg
ignition help
Just bought a bezel and it doesn"t go over cylinder.I don"t know if previous po changed ignition or if this will separate.
I have seen separated cylinders and ignition switches.this is on 1966 chevy c-10.
LIFE NEEDS NO RED LIGHTS !! 1966 chevy stepside. Aka Bella. 1998 chevy s-10 4x4 daily driver. my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=467164 |
07-02-2012, 03:10 PM | #2 |
Re: ignition help
Does the cylinder have the key slot cover with a small hole on the front? If so, insert key and turn one position and depress the spring in the small hole w/a paper clip. This willl allow the bezel to go on over the cylinder and them reinstall the cover. If not, please provide a pic of the cylinder so we can try and help you out.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-02-2012, 05:50 PM | #3 |
Blackdawg
Re: ignition help just uploaded pics
forget the pics
07-02-2012, 05:57 PM | #4 |
Re: ignition help
you have to take the cylinder out of the ignition housing and screw the housing in with the bezel into the dash and then reinstall the key cylinder....like stated above.
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
07-02-2012, 06:07 PM | #5 |
Re: ignition help
step one find off postion:
step two insert key turn to the left to acc. postion! (this takes two hands just using one for picture) insert paper clip/sewing needle in top hole,and while pushing down pin with a spring inside(might take a couple trys to make sure your pushing down the pin, make sure you insert paper clip straight in) turn the switch to the left one more turn and pull out: vola!!! put the bezel and housing in dash and then reinsert key cylinder and turn to the right: sometimes reinstalling the key cylinder into key housing you have to use the opposite/other hole and push the pin down while turning right to get it to go back in hope that helps!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 07-02-2012 at 06:22 PM. |
07-02-2012, 07:46 PM | #6 |
But Found Her 25yrs Later!
Re: ignition help
It does look like you don't have the correct plug for the back of the switch.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-02-2012, 08:22 PM | #7 |
Blackdawg
Re: ignition help
excellent thanks for the help.
