Old 07-02-2012, 12:56 PM   #1
jaros44sr
jaros44sr's Avatar
winters quick change
Has anyone stuck a quick change rearend under our trucks? Thought it would allow me have highway gears for the road trips, but still run 3.73's around town
Its a 4x4 with a twin stick NP205, so i can put it in 2wd, front or rear
Any thoughts, tried search, but couldnt get it to work....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-02-2012, 03:10 PM   #2
jaros44sr
jaros44sr's Avatar
Re: winters quick change
Ok, already a snag. Winters will set it up with with ford backing plates, but have axle drilled for chevy lug pattern. How do i find ford drums with no holes, so i can run chevy rallies
Is there a company that makes drums, so i can ask them to drill chevy bolt pattern in them
Dormann?
SAFETY FIRST
AS usual, off topic
Jim
Old 07-02-2012, 03:47 PM   #3
Scottshotrods
If you are going to invest the money in a winters quick change rearend for your truck.You should consider upgrading to disc brakes on the rearend to.Just a thought
Justin
Scottshotrods is offline   Reply With Quote
Old 07-02-2012, 04:11 PM   #4
LEEVON
Moderator
LEEVON's Avatar
mmmm...cool factor but expensive. Also expensive, but easier than changing gear would be a gear vendors overdrive.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-02-2012, 06:11 PM   #5
jaros44sr
jaros44sr's Avatar
Justin
Leevon, didnt know you could fit a gear venders behind the transfer case.....
Justin, would consider it but, i have two handbrakes, so i can lock up each rear wheel separately
SAFETY FIRST
AS usual, off topic
Jim
Old 07-03-2012, 01:57 AM   #6
andrewmp6
Why not a ford 9 inch?You could run a 9 inch and have 2 different center sections set up how you want.Once you pull the axles out the center section is a few bolts.And with a 9 inch you can build a high pinion for more ground clearance off road too.
andrewmp6 is offline   Reply With Quote
Old 07-03-2012, 11:49 AM   #7
cajundragger
they aren't very strong.
you'll prob want the "3/4 ton" dirt car rear end.
looks very similar to the classic but its huge.
cajundragger is offline   Reply With Quote
Old 07-03-2012, 01:27 PM   #8
cdowns
cdowns's Avatar
like this
Old 07-03-2012, 11:11 PM   #9
jaros44sr
jaros44sr's Avatar
Ok, guys.... Think im changing plans. 700R4 trans. Still like this idea, easy to change final drive
Didnt know about the "3/4" ton axle, also didnt know they werent strong
Downs, thanks for the pic
SAFETY FIRST
AS usual, off topic
Jim
