Old 07-02-2012, 04:07 PM   #1
terry b
terry b's Avatar
wtb rear sport bumper mounting brackets.
1972 C 20 with rear leaf springs. Need sport bumper mounting brackets.
terry b is offline   Reply With Quote
Old 07-04-2012, 01:38 PM   #2
terry b
terry b's Avatar
Re: wtb rear sport bumper mounting brackets.
come on no one going to help me out. can i use coil spring brackets. or at least part of them?
Old 07-04-2012, 08:29 PM   #3
JimKshortstep4x4
If you have a long bed you will probably be able to use the inner brackets from a coil spring truck. The outer brackets will work.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-04-2012, 08:37 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
http://www.classicparts.com/1967-72-...tinfo/65-348B/
Keith
Convert to disc brakes.
Old 07-04-2012, 08:48 PM   #5
DREW67
DREW67's Avatar
Keith are you saying this will work on a 2wd leaf spring truck. I too been looking for a set.
DREW67
DREW67 is offline   Reply With Quote
Old 07-04-2012, 08:59 PM   #6
lolife99
lolife99's Avatar
Classic Parts lists these and 2wd brackets.
As far as I know there are only 2 different sets of rear sport bumper brackets.
I'm guessing since all 4x4 trucks are leaf spring.
I was hoping someone else would chime in.
Keith
Old 07-05-2012, 03:33 AM   #7
70LonghornCST
Moderator
70LonghornCST's Avatar
If you have a 4X4 or a SWB it takes one size of rear bumper brackets.
If you have a stepside, SWB with coil, LWB with coil, LWB with leaf, or a longhorn, it takes the other size.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 07-05-2012, 08:16 AM   #8
DREW67
DREW67's Avatar
The mystery is solved then we can use 4x4 brackets and we should be good.
DREW67
Old 07-05-2012, 01:12 PM   #9
tll74
"Junkyard Dog"
tll74's Avatar
Where does the Sub outers fall into the equation?
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 07-05-2012, 02:09 PM   #10
terry b
terry b's Avatar
Thank's the help was needed. I did not want to put the old HUGE bumper back on. Also yes it is a long box. Thank's again.
Old 07-05-2012, 08:01 PM   #11
JimKshortstep4x4
Sub outer brackets are the same as for the trucks.
Jim
Old 07-06-2012, 01:08 PM   #12
tll74
"Junkyard Dog"
tll74's Avatar
So..are the outers the same regaurdless if it a PU, Sub, or BLazer and the inners are the only difference?
Old 07-06-2012, 07:20 PM   #13
JimKshortstep4x4
Outer brackets are the same regardless. On the 72 Blazers and Burbs, the frame was used for the inner brackets.
Jim
Old 07-06-2012, 07:36 PM   #14
lolife99
lolife99's Avatar
Jim
Did all 67-72 burbs use the frame for the inner bracket?
I know my old '69 burb did.
Keith
Old 07-15-2012, 03:47 PM   #15
terry b
terry b's Avatar
ttt
Old 08-27-2012, 09:19 PM   #16
dropanddrag71
dropanddrag71's Avatar
Terry,
What did you use that worked? I have a 1970 c 20 longbed with leafs and want to install a sport chrome bumper... was it a bolt on or did you do any mods? Did you install the filler panels as well? Any part numbers on the brackets?
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
