Old 07-02-2012, 05:35 PM   #1
eugrides
wiring one wire alt
how do i wire amp guage with one wire 12 volt alt on 53gmc
eugrides is offline   Reply With Quote
Old 07-13-2012, 03:56 PM   #2
hotrodsbyray
Re: wiring one wire alt
I'd recommend switching to a voltmeter. Ammeter can be a possible hazard, especially with a newer 12 volt system. Mad Enterprises has a lot of good info on their web site about alternators, gauges, and such that is very practical. Might want to take a look. Oh, yeah - I'm not affiliated with them, I just like the technical info they have.
hotrodsbyray is offline   Reply With Quote
Old 07-13-2012, 05:15 PM   #3
koda360
koda360's Avatar
I'm not sure you can add an amp meter to a one wire alt. Don't quote me on that just yet and let me double check, but I think that's one of the downfalls to the one wire alts....
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 07-14-2012, 11:46 AM   #4
_Ogre
_Ogre's Avatar
your 53 amp gauge is 30 amp, a typical 1 wire alternator is 100 amp.
i would hook a 10 ga wire from the post on the alternator directly to the battery
by-pass all the under dash wiring and a possible wiring fire
i converted the amp gauge on my 58 to a volt gauge, look in my truk build for info
if your the adventurous type, try converting your stock amp ga to a volt gauge
shop air compressor timer
Old 07-14-2012, 12:55 PM   #5
RootBeer 6117
RootBeer 6117's Avatar
Try here under electrical tech you should find an answer, I have done it but don't remember all the details.
http://www.madelectrical.com/index.shtml
RootBeer 6117 is offline   Reply With Quote
Old 07-15-2012, 12:33 AM   #6
mknittle
mknittle's Avatar
I did the one in my jeep with an amp meter with no problems about 6 years ago and it is a 100 amp alternator. I also run dual isolated optmas in the back.
that connect through relays when the winch is activeted.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-15-2012, 12:05 PM   #7
AZ59apacheguy
I have a one-wire hooked up to my '59 and I still use the stock amp meter. What I was told to do ( from So-Cal Speed Shop ) is take a 10ga wire and jumper between the two posts on the back of the gauge. The reason for this is to tame the current accross the gauge and make it less sensitive. I still see the needle move to the right upon startup and then it settles down after running for a while.
AZ59apacheguy is offline   Reply With Quote
Old 07-15-2012, 01:32 PM   #8
mknittle
mknittle's Avatar
I didn't do mine that way. and It works fine. I would think the wire across the termenals would make the guage in accurate. Like I said it is 100 amp and is stable. May be the stock guage is more sensative
Mark
My GMC build.
Old 07-15-2012, 03:18 PM   #9
AZ59apacheguy
Before I installed the 10ga jumper the needle would jack all the way to the right of the gauge. I was told as long as you see trending from startup to normal operation you were fine.
Old 07-15-2012, 03:26 PM   #10
Russell Ashley
Russell Ashley's Avatar
I posted on keeping the original amp guage back in January. Here is a link if anyone is interested.
http://67-72chevytrucks.com/vboard/s...d.php?t=505185
It is true that the jumper would cause the amp guage to read lower than it would without it. That was the purpose of putting the jumper on my guage, so it wouldn't peg when the alternator was charging at a high rate. The original amp guage is only marked "C" and "D", not a specific number of amps so it would not be correct to call it inaccurate. It's just an indicator that the charging system is (or isn't) functioning as it should. I wanted to keep my gauges looking and acting completely original and that's why I did it like I did.
I never saw this suggested anywhere else. I wonder when So-Cal started giving out this tip.
Russell Ashley is offline   Reply With Quote
Old 07-15-2012, 04:28 PM   #11
AZ59apacheguy
I don't know. I went there and asked if they had a aftermarket voltage gauge that would adapt to a 55-59 instrument cluster. He said no one made anything like that, that's when he gave me that 10ga jumper trick.
Old 07-15-2012, 05:07 PM   #12
eugrides
Thanks 4 all the info. Found out from auto rewire it would be fine to wire guage in series from alt. 2 bat. Using a fusible link my alt. Is 63 amp and guage is 50 amp
Old 07-15-2012, 05:22 PM   #13
AZ59apacheguy
Hi. It's always a good idea to have a fusable link between battery and and cab wiring..
Old 07-15-2012, 09:06 PM   #14
mknittle
mknittle's Avatar
that works, thanks Russell
Mark
My GMC build.
