07-02-2012, 05:54 PM | #1 |
Help!!! LOL
Having serious problems with wheel hop. 1969 C-10 lwb ford 9", stock trailing arms, A-body rear springs, stock six cylinder front springs. I have already broke a few axles it wheel hops so bad.
07-02-2012, 09:06 PM | #2 |
Re: Help!!! LOL
never had much trouble with hop on trailing arms. I would try some adjustable rear shocks.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-02-2012, 10:00 PM | #3 |
It's Better With Nitro
Re: Help!!! LOL
There are a lot of things that can contribute to wheel hop on a launch, but my first question is what kind and size of tire are you running, and at what pressure?
07-02-2012, 10:13 PM | #4 |
Registered Truck Offender
Re: Help!!! LOL
If you come back saying you have air shocks were gonna slap you silly (lol) Air shocks are notorious for wheel hop. You know that right.... but with the luck others have with the trailing arm suspension,, I'd agree it's gotta be shock or tire like Kevin and Vin are saying.
I would also ask how hard your hiting the tire with power? What kind of 60 and 1/4 mile ET/MPH are we talking about here? Happy 4th of July to all our boys serving world wide. THANK YOU
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 07-02-2012 at 10:26 PM. |
07-03-2012, 03:40 PM | #5 |
Re: Help!!! LOL
It has regular kyb's on the back. Truck has 295/65-15 mt drag radials and a sbc. It is a mild 421 with steel sportsman heads a mild .500lift solid cam and a th350 trans. I just put this motor in it. But with the old 355 it ran 7.63 and would 60ft 1.60's. I have tried running some 28x10.50-15 slicks and it still hops bad. I am tired of breaking axles.
07-03-2012, 03:50 PM | #6 |
Re: Help!!! LOL
Make sure there is no bind in the rear suspension.
Check the rear bushings. Try putting a diferent shock on it. Does it have a rear aniti roll bar?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-03-2012 at 03:58 PM. |
07-03-2012, 05:35 PM | #7 |
Re: Help!!! LOL
No anti roll bar. Nothing seems to be binding. The truck tries to transfer weight but then seems like it just unloads and starts hopping. The truck used to hook in a mud hole! LOL After I lowered it a couple of inches it has been crap ever since.
07-03-2012, 06:49 PM | #8 |
Re: Help!!! LOL
You just answered your own question. How did you lower the truck? Springs?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-04-2012, 09:41 AM | #9 | |
Re: Help!!! LOL
Here is some general reading about pinion angle, ride height, etc. http://www.deanoshiro.com/suspension/setup.html http://www.rosslertrans.com/Pinion%20angle.htm
07-04-2012, 02:16 PM | #10 |
Re: Help!!! LOL
Did you lower it at the same time you put the new bigger motor in?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-04-2012, 02:20 PM | #11 |
Re: Help!!! LOL
It was lowered before the new motor install.
07-04-2012, 02:28 PM | #12 |
Re: Help!!! LOL
Did it have traction problems lowered with the 355?
What did you do to lower it?
07-05-2012, 10:02 AM | #13 |
Re: Help!!! LOL
I've had traction issues ever since I lowered it. I guess I need to try changing rear springs.
07-05-2012, 12:05 PM | #14 |
Re: Help!!! LOL
The springs are one of the last things I would change in a wheel-hop-on-launch issue, but feel free to change out what you like.
07-06-2012, 10:06 AM | #15 |
Re: Help!!! LOL
07-06-2012, 02:39 PM | #16 |
Re: Help!!! LOL
I would put an adjustable shock on the rear. You will then be able to adjust it to hold the tire down. Right now, it appears that you are not able to control the lighter rear spring, and it is oscillating out of control. The shock is designed to control this characteristic. The heavier springs originally in it resisted being compressed, which helped you some. I hope this helps some. Paul
07-10-2012, 10:03 AM | #17 | |
Re: Help!!! LOL
07-15-2012, 01:09 PM | #18 |
Re: Help!!! LOL
I agree with the above post on springs, shocks and pinion angle. My first thought was the shocks but if you changed springs and lowered it, springs could possibly be the problem. I would definately start with checking pinion angle. If you didn't adjust pinion angle to compensate for the lowering that could be the majority or even all of your problem and it's a simple cheap fix. Pinion angle can make all the difference in the world on something that hooks and something that spins.
Posted via Mobile Device |
