rear wiring harness same 88-95?
got a tail light that's not working. Shop says its the back harness that's cut and split into a few times over. I said I have a 88 parts truck. Is the rear wiring harness the same? If so I should be able to undo this one and put mine on it. This is at the Y where the tail lights meet for the rear harness.
he said if I had a harness that would be the simple route unplug one and plug other in.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
Re: rear wiring harness same 88-95?
It should be the same unless you have a trailer harness. if you just have 4 wires on all parts then it is the same. Make sure you hook that ground back up, it will not work without it.
2001 GMC 2WD, 1998 Chevy K2500 |
| Bookmarks |
