Closed Thread
Old 07-02-2012, 09:04 PM   #1
jwgeorge
Rust-free 68-72 Cab For Sale
I have a 68-72 truck cab for sale that is rust-free. I have owned it since April 2011 and it has been garaged the entire time. The floorboards have no rust, the rockers have been replaced and the roof has been replaced. It is a non-A/C cab, but has an uncut dash. The inside rear roof seam needs to have the weld ground and smoothed. It has a hole chopped in the tunnel (low tunnel) for a shifter, but I have a piece to replace that from an original floorboard. The fuel filler neck hole has been filled-in. The previous owner did all the work and took the cab to a shop to be finished and they weren't doing it the way he wanted (the shop was starting to bondo things) so he took it home and decided to sell it for a truly original rust-free cab. I bought this cab to use with my 68, but then decided to build a complete second truck, now I just need the cab out of my garage, I need the space! Something has to go and I would rather sell it to someone that needs it than move it to the backyard and have it start rusting. It is not perfect, it needs some touching-up before primering but it is rust-free. I am asking $500 for the cab. It didn't come with a VIN tag or a title and it will be sold without a VIN tag and a title. I am located in Pearland, TX, on the southern edge of Houston.
1968 C-10 Longbed, 6-cyl., 4-speed.
832-584-1245
"You see, in this world there's two kinds of people, my friend, those with loaded guns and those who dig."
jwgeorge is offline
Old 07-02-2012, 09:18 PM   #2
jwgeorge
Re: Rust-free 68-72 Cab For Sale
More Pictures
832-584-1245
jwgeorge is offline
Old 07-02-2012, 09:21 PM   #3
jwgeorge
Even More Pictures
832-584-1245
jwgeorge is offline
Old 07-02-2012, 10:45 PM   #4
jtp67-72
jtp67-72's Avatar
jw, I've built many of these trucks and something doesn't look right on the roof of this cab..not being critical at all just hit me with the second pic and others...unless it's just the pics roof looks pitched up in front...may be me though...I would have to see a door mounted ..if not it should bring the money...jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline
Old 07-02-2012, 10:54 PM   #5
Chevy072
I noticed that as well.
Chevy072 is offline
Old 07-03-2012, 12:06 AM   #6
jwgeorge
I believe that would just be the camera angle. The previous owner had bolted doors on after the roof replacement and everything fit correctly. I guess I could take pictures measuring the door openings from the roof to the rockers in a couple of places to show that the roof is where it should be. Thanks for pointing out how it appears in the photos. I will add more pictures with the necessary proof of the roof.
832-584-1245
jwgeorge is offline
Old 07-03-2012, 08:03 AM   #7
oklalawnboy
oklalawnboy's Avatar
That's what I thought too but it does look like the whole cab is tilted back so maybe that was it.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline
Old 07-03-2012, 11:31 PM   #8
jwgeorge
OK, So I took a measuring tape to the cab and the top door seal edge is parallel with the rocker. I checked this several places on this cab and verified this on the cab of my 68. I still need to post some pictures of this to make sure no is spooked by this.
832-584-1245
jwgeorge is offline
Closed Thread
