SM465 wires
I got my automatic going in the blazer finally and was taking care of some loose ends. The dark green and light green wires going to the 4 speed are the back up lights. What is the lone black wire for? Neutral switch? If it is it never worked. I tryed to find it on my GM wireing diagram, but had no luck.
Thanks, Randy ![]() ![]()
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
The other switch on a 465 (besides the reverse gear ind.) is a high gear switch for the TCS system. The switch grounds the wire when the tranny is in 4th gear.
Tim |
thanks Tim!
No need for that wire any more. Randy ![]() ![]()
Careful, they attack...
TCS system? What's that? Never heard of it.
Transmissin controled spark...?
Really, or are you just guessing?
Yes, Transmission Controlled Spark. Do a search if you are interested in how it works.
Tim |
