boosted battery now it wont run
hi guys i went to boost my battery on a 1994 chev truck and it was red on red black on black but it sparked and now the truck will turn over but not run not sure what the problem is any help would be great thanks alot guys
Old Skool Club
![]() Join Date: Jun 2001
Re: boosted battery now it wont run
Sure hope I never have that problem.
I've jumped a few and my boss has jumped a buncha school buses with his '90, and so far no problems. But, the spark is worrisome. Without being there....it's hard to say what happened. But, CPU's are sensitive. Do you have a Check Engine light? Have you run the codes? I know you have an ALDL connector, so you have to short the right terminals to get the CEL to flash the codes it has stored. If you will do a search on this forum for an ALDL connector, you should be able to pull up the how-to and a list of codes.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
well it was a fusible link that had burned but now it cranks over fine but there is no spark
| Bookmarks |
