07-03-2012, 05:59 PM | #1 |
newbie here. 4x4 frame question.
I just started a frame off restore on a 71 short bed 4x4. I want to disassemble the entire frame, by removing all rivots. this would allow me to blast all hidden areas. Has any one out there done this. If So, Any suggestions if its a good idea or bad idea. I intend to bolt the frame back together with grade 8 stainless bolts.
07-03-2012, 06:28 PM | #2 |
Re: newbie here. 4x4 frame question.
Use lock tight on all the bolts and hope they don't come loose. That ride might get interesting.
07-03-2012, 09:04 PM | #3 |
stainless bolts = you truck flying apart, drill all holes out to the next larger size as the bolts will be thinner than the rivet bodies, use fine thread bolts with lock nut.(crush type)
lifted, locked, rockin |
07-04-2012, 03:05 PM | #4 |
I sure wouldnt remove anything that is riveted on.......
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
07-04-2012, 03:39 PM | #5 |
X2, Rivets and bolts don't just interchange under shear loads. Grade, type, size, and material are all factors. If this is foreign to you, then your best bet would be to check the bare frame X,Y and Z axis. True and repair as needed then blast and prime it.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-05-2012, 05:46 PM | #6 |
Its got some pretty bad rust,in a couple areas. those parts are gonna have to be replaced. I suppose I could just replace those parts. using grade 8 steel bolts with lock washers and loc-tite. I just know theres rust behind those riveted parts, that the blaster cant get to. Thanks For Your opinions
07-05-2012, 05:56 PM | #7 |
Hey bowhunter65
to your new internet truck family and from Ohio. Best of luck as you do your rebuild and don't forget we luv pics
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-05-2012, 06:19 PM | #8 |
hey 70cst Thanks for the warm welcome. I made a rookie mistake. didnt take any pictures before starting the tear down. I have taken many Since Then. Will have to get the wife involved as I am computer stupid.
