Old 07-03-2012, 08:43 PM   #1
SRVBLUES64
cam install
If I pulled out my cam only to put it back in (long story) do I have to use cam lube again? also on a 350 74/85 engine is there a cam retainer plate that goes infront of the cam to hold it or does the gear hold it in place?
SRVBLUES64 is offline   Reply With Quote
Old 07-03-2012, 09:28 PM   #2
bama63
bama63's Avatar
Re: cam install
yes on cam lube and make sure the lifters go back in the same bore they came from, you can use a piece of 2x4 and a butterfly bit for the lifters to sit in and mark the front and rear so you know the proper location, and no retainer is used on the v8 just the thrust surface on the cam gear
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-04-2012, 10:19 AM   #3
'63GENIII
'63GENIII's Avatar
Red face Re: cam install
What do you mean by a cam retainer plate? Are you talking about the plate that locks the cam bolts? I've always used a cam button on the front of my smallblocks and that was held in by that bolt locking plate. I was told that it helped keep the cam from walking. As far as the cam lube, any time that I have pulled a cam to replace it with another cam I have not put the lifters in any kind of order because I was replacing them with new ones. I have had to reuse 2 cams that I had pulled also. Both times I had to get new lifters. If you have kept them in order and are sure they are going back into their original bores, no need for lube as they already have their wear pattern established. It won't hurt but is not necessary.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-04-2012, 12:32 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: cam install
http://www.carcraft.com/howto/ls1_en.../photo_07.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
