Old 07-03-2012, 09:12 PM   #1
rustbelt
rustbelt's Avatar
First timer = first question
I've enjoyed wandering around the site, while looking for my first old truck. I've always admired the early 60's Step-side pickup and picked up a 61 this weekend. I planned on cleaning it up a bit before showing her off to you guys, taking pictures tomorrow.
Meantime, I have 2 questions: 1) How do I tell if my truck is a C10? and 2) how is the cable for adjusting the bench seat attached on the drivers side?
Thanks for any help, I'm looking forward to the adventure.
Rustbelt
rustbelt is offline   Reply With Quote
Old 07-03-2012, 09:20 PM   #2
McCoyAZ
McCoyAZ's Avatar
Re: First timer = first question
Welcome to the boards.
I can't answer either one of your questions though.
You will be amazed at the amount of information available to you here.
McCoyAZ is offline   Reply With Quote
Old 07-03-2012, 11:38 PM   #3
jbgroby
jbgroby's Avatar
Welcome. We LOVE pictures.
jbgroby is offline   Reply With Quote
Old 07-04-2012, 12:15 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum.
If you have as standard pickup truck the easiest way I know of to identify the model number of the truck you have is by the number of lug nuts and drive axles. If it is an unmodified Chevy and has 6 lugs it’s a ½ ton which would be a C10. If it has 4 wheel drive it would be a K10. If it has 8 lug wheels it would be a ¾ ton which would be designated C20 or K20.
A C30 or K30 would be a 1 ton chassis, but I’m not familiar with specifics that would identify the details.
Another method to determine the original configuration of the truck is to run the VIN through one of the decoders. This will confirm how the truck started life. If you have trouble with the VIN just post it here and someone will break it down for you. Here’s one link that may help:
http://67-72chevytrucks.com/vboard/s...d.php?t=463671
I don’t have a photo to show, but there are two latches (one on each side) under the factory bench seat. There is a single length of piano wire that connects the two, so that operating the lever on the driver side unlocks both latches. If the passenger side won’t unlock, the connecting wire is either stretched, broken, or missing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-04-2012, 01:37 AM   #5
jocko
jocko's Avatar
1/2 ton VIN will have 3rd digit as a 1, whereas 3/4 ton VIN will have 3rd digit as a 2
for example:
a 1/2 ton 2wd swb 61 would start off as: 1C14
a 1/2 ton 2wd lwb 61 would start off as: 1C15
a 3/4 ton 2wd lwb 61 would start off as: 1C25
4wd would have a K in place of the C
Old 07-04-2012, 02:21 AM   #6
MikeS.
MikeS.'s Avatar
Welcome to the club!
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-04-2012, 04:54 AM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
and the c/10 didnt start until 62.. 60-61 are apache 10-20-30
Old 07-04-2012, 05:06 AM   #8
losthope
losthope's Avatar
Hmmm, didnt know that.. I wondered what made a truck apache thanks Jon! learn something everyday!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 07-04-2012, 06:06 AM   #9
rustbelt
rustbelt's Avatar
Thank you gentlemen for the information. The PO has made some changes on the truck so it could put a twist in identifying exactly what rolled out of the factory as. There are 6 lug nuts on each wheel. It appears the rear axle is not original to the truck. The VIN # is 1C253N110635. I was told it was a short box but if I'm deciphering correctly, the VIN indicates a long box. What do you guys make of it?
Old 07-04-2012, 08:34 AM   #10
jonzcustomshop
1961 crewcab
here is the vin you have decoded:
VIN Format: 1960-1964 Chevrolet Truck
Decoding: 1C253N110635
Digit Usage VIN Decoded
1 Year 1 1961
2 Type C Conventional (2WD)
3-4 Model 25 3/4-Ton
5 Body 3 Chassis & Cab
6 Plant N Norwood OH
7-12 Sequential Serial # 110635 110635
*** all 3/4 tons were long box.
Old 07-05-2012, 08:02 PM   #11
rustbelt
rustbelt's Avatar
Thanks jonzcustomshop for the decipher. Another question if I may - what is the actual inside box length of a long box compared to a short box? Also, am I correct that if it's a 3/4 ton then it's a C20?
Old 07-05-2012, 09:38 PM   #12
jonzcustomshop
1961 crewcab
yes 20 series is a 3/4 ton 8 lug wheel
lb is 8 feet, sb is 6 feet inside; outside they are about 7 inches longer than inside each.
it is pretty easy to switch the 1/2 ton stuff to the 3/4 ton frame, that is if your cab vin and frame vin match.. it is even easier to bolt a good 3/4 ton cab with a title to a swb frame if that is what one wants.
a couple scenarios of what might have happened with your truck.
check out this thread to help find the vin that should be stamped on your frame:
http://67-72chevytrucks.com/vboard/s...d.php?t=316902
Old 07-06-2012, 01:58 AM   #13
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
It's starting to sound like you have a cab from a 3/4 ton truck sitting on a 1/2 ton frame.
Find your frame VIN as jonzcustomshop suggests.
66 C20 Service Truck:
