Alternatives to rubber fuel hose?
Seen a lot of guys on here against the rubber fuel line. What's my alternative? Best place to buy? Links would help. I like pictures too
![]() Posted via Mobile Device
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() |
Re: Alternatives to rubber fuel hose?
I dont think a little rubber would hurt.There is a nice kit at autozone for your carb that goes from carb to the filter.Then buy a fuel line from classictube and modify a little bit.
I am a Referee of life.
I always use a small section of rubber to allow for movement.Steel braided works well also.I think routing and condition should be shecked but I usually swap it every time I do a tune up,when I change the fuel filter.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
There are many kits to make a safe fuel line from the pump to the carb. Look on summit or jegs. Hard line or braided flex line, your choice. O'Reilly's carry a braided line kit, as I'm sure other local DIY stores do to. Rubber fuel lines from the pump to the carb are the number one cause of vehicle fires. The line ruptures and the the pump sprays fuel under the hood until the engine dies. A gallon or so of fuel can be pumped out before the engine uses up the fuel in the bowls or until the drive sees the smoke and gets pulled over.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#5 | ||
"I ain't nobody, dork."
The options are almost endless.
You must have some sort of flexable fuel line from the tank to the hard line on the frame, and then from the frame to the fuel pump to allow for flex of the frame and body. From the pump to the carb, you can bend your own hard line, or run a braided line with AN fittings. Here is the line I bent and double-flared myself out of 3/8" steel tube. The line: Installed in truck: What I bent and flared it with: I'm running a Carter "Street Pump" and a Holley 3310. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
cool! I like the idea of an entire hard line. right now i have an old hard line that runs up to the intake/valve cover area and then i have about 1.5ft or so that goes to the carb.
Anyone have links to the hard line kits or the kind that has an inline filter?
#8 | ||
You can search almost any parts warehouse like Summit Racing or Jegs for fuel line kits.
But... most hard line kits are self bent. Some of the aftermarket parts guys will probably have a stock replacement hard line for a Q-puke. Gary
#9 | |
Active Member
![]() Join Date: Jul 2007
I've been having trouble locating one in the local auto parts stores. |
#10 | ||
My parts store has 4 foot lengths of straight tubing with 2 brashh NPT fittings preinstalled and the ends are double flared. So if you have to cut it... you have to reflare the end yourself.
They sell them from 3/16" up to 1/2". Steel, Stainless Steel, and some with a greenish coating on them. I almost wanna say they get them from Dorman... but I would have to check. Gary
#11 | |
Active Member
I needed 5/16" line for my 71 with 307 and 2bbl. 30 inch was perfect length from pump to carb inlet. I got lucky and made all the correct bends on my first try.
Hardest part is keeping the line from touching the lower radiator hose. I highly recommend a quality tubung bender like the one in GASoline71's last pic. |
#13 |
Am I correct in thinking a very short section of rubber fuel line is good to absorb vibration.
#14 | |
I will be doing that on my 72 with 350 and 4bbl. I'll use 3/8" steel from the pump and get it close. Then I'll finish the run with rubber. Be sure to use quality fuel hose and good hose clamps, maybe even double up on the clamps. |
#15 | |
Active Member
There really isn't any noticeable vibration between fuel pump and carb and some of these fuel lines have been there for decades without problems. People that add one in there is usually for an inline filter. |
#16 |
Grandpa in the rustmobile...
Gary, Where/whatre you using for a fuel filter. Very clean good job
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#17 | ||
The filter is in the housing in the front of my dual feed fuel line for my Holley. It's got a big brass filer in it...
This is it: http://www.summitracing.com/parts/SUM-G3120-2/?rtype=10 It also has a fuel pressure guage with it. This is the line installed on the truck.... Gary
#18 |
I have something similar but on the stock q jet. I want the least amount of rubber line possible, less change for the rubber to deteriorate and leak fuel.
#19 |
Cruzin
i use steel brake lines for my fuel lines they are cheap and easy to get at any local parts store in a several sizes and lengths. I use them also to replace vacuum lines.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#20 |
#21 | |
#22 |
The metal line most of us use is just 3/8 brake line with double flares on the end, use one end and make your own flare on the other side (i took mine to someone lol it takes practice/tools)
thanks gary very clean
#23 | |
Any link to the fitting? Couldn't find it on summit ![]() Posted via Mobile Device
#24 |
ttt. anyone know what fitting id need to go from this kit to rubber hose?
http://www.summitracing.com/parts/EDL-8131/?rtype=10
#25 |
Would this work?
http://www.summitracing.com/parts/DER-98200/ So all in all it would be Carb > fuel line and filter > FITTING > 3/8" rubber hose > hard line connecting to fuel pump
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() Last edited by dmw319; 07-10-2012 at 10:58 AM. |
