Yepper I have spent enough time trying to figure out how to properly hing the light housing, so that it would not hit the box side when opening. I am going to sell the Blazer tank and buy a fule cell and run the filler thur the bed floor. I usually would not give up on a good Idea but I will make this a exception.
Later ![]()
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 05-18-2003 at 09:48 PM. |
Damn!!! I was watching this progress to attempt it myself. Oh well...I have more time to figure something out too, but I have considered the floor filler with the blazer tank. Good Luck!
69 GMC K10 ..some restoration required....still.. ![]() |
It was just way to difficult for me. I did not want to stop but it has taken at least a week of 6 hour days and no progress.
I wan't to get this project moving so I am going to go the on the more travled route and do it the easy way. If you have lot's of time and really good brain power it is doable I have seen 3 Blazers with it done to them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 05-18-2003 at 03:15 PM. |
72 mario put a pick of your truck man
70 longbed 496/th400/Ford 9" |
i seen one post on here few months ago were the guy ran the filler neck up the corner of bed and uesed s-10 gas door to hinge the side marker light it was kool and he had pics of the complte pross.do search on side marker light gas door it might help
I'm tryin to figure out how to fill mine up too. I have a friend that makes kitchen cabinets, he suggested looking at some cabinet hinges that push out as they swing around. Maybe you could check out a hardware store and see what they got. I've been working on this one too for a while, I feel your pain.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
I got a hinge from the Home Depot this afternoon as it opend it pops out mabye it may work. I guess I will try it again. I have the filler tube and neck all setup and in place just waiting for the hinged light and it's set.
Still looking for advice.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
dude post a pic of your truck
I will trake some pics this week and post them in a new thread.
I have to borrow my Girlfriends sisters digi cam.
