Old 07-04-2012, 11:07 AM   #1
dmw319
Question How to connect auto column shift linkage??
So I've got all these parts and not sure what goes where. Anyone wanna walk me through how to do it? Here's what I've got:
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 07-04-2012, 11:52 AM   #2
Lee H
Lee H's Avatar
Re: How to connect auto column shift linkage??
OK, I'll start. Red part bolts onto trans shift rod with nut that I don't see in your picture. Larger rusty part bolts to frame. Rod with slip on union/bolt goes to the column shifter lever. The black part has a hole in one side that goes over the rod on the frame mounted part, the opposite side mates up to the red part, the black part is held in place onto the frame part by the spring, washer and cotter pin in the picture.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-04-2012, 12:34 PM   #3
Boog
laying low
Boog's Avatar
Here's a shot from down under.
Donated by Frizzle Fry.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-04-2012, 12:56 PM   #4
dmw319
hmm ok thanks! so looks like all i am missing is a nut.
Also, thanks for the pic! any picture of where the rod with the slip/on union bolt goes to the shifter lever?
Old 07-04-2012, 01:06 PM   #5
sbc10guy
sbc10guy's Avatar
That helps me out as well. Thanks for posting.
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 07-04-2012, 01:16 PM   #6
Boog
laying low
Boog's Avatar
The rod connect at the column end is straight forward. Place trans linkage in park, inside shift lever in park and attach the linkage rod to the lower column lever, tighten down the setscrew.
Boog
primer is finer
Old 07-05-2012, 04:41 PM   #7
dmw319
ok thanks! might try to tackle this soon. not sure i have every piece i need for that, do i?
Old 07-05-2012, 07:07 PM   #8
dmw319
Anyone have a pic? I can't figure out how the other end connects. Just a picture would help? Not sure if the column I have is a floor or column shift
Old 07-05-2012, 07:13 PM   #9
c1069
c1069's Avatar
Try these links
http://67-72chevytrucks.com/vboard/s...d.php?t=215499
http://67-72chevytrucks.com/vboard/s....php?p=3585119
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 07-05-2012, 07:14 PM   #10
dmw319
This is my column:
It looks like the rod should connect through those 2 linkage brackets on the column but the angle doesn't seem right. Something I am missing?
Old 07-05-2012, 07:16 PM   #11
dmw319
Judging by the pics in the second pic I don't think I have the right column.
Old 07-05-2012, 07:22 PM   #12
c1069
c1069's Avatar
its the same shape of our columns, I cant judge that pic 'cuz is incomplete. If you need more pics just Type AUTO COLUMN SHIFT LINKAGE in the upper right box then click in 67-72chevytrucks.com spot(circle) and the GOOGLE button
Pancho
Old 07-05-2012, 09:34 PM   #13
Boog
laying low
Boog's Avatar
This is my column:
That second pic looks like there are 2 levers on the lower end of the column. If so it's a standard shift column. Only 1 lever for an automatic.
Boog
primer is finer
Old 07-05-2012, 09:40 PM   #14
dmw319
Yep, now I need to find the right column!
