Old 07-04-2012, 01:47 PM   #1
coltonk
coltonk's Avatar
New Paint, Now to buy rims
well truck is in the paint booth finally and had a bad problem with the paint and the "matte clear" mixing together and it didn't come out the way i wanted it to when it got painted it was really hot then a few hours later a storm came through so the guy who is painting it for me said he thinks it was the humidity. so he is in process of wet sanding it and seeing if it he can't fix it. Its driving me crazy. Im using John Deere Blitz black with 8:1:1 ratio just incase anybody was wondering.
But while thats getting fixed its time to get new wheels and tires. Im set on either Boss 338's (chrome) or Coys c-5 (black Chrome) I just need help on wheel sizes as well as tire sizes. the truck is lowered 2/4 and wanting to do a staggered look with 18x8 up front and 20x10 on back. Maybe somebody already has this set up and can show pics even with different rims. However i don't know which route to go with tire sizes. any suggestion and or opinions would be great help.
here is a pic of the truck in paint booth with the blitz black with the messed up matte clear, hoping to get that fixed by weekend. and here is the truck before any body work.
"How does a posi-trac work on a Plymouth?.. it just does!"
coltonk is offline   Reply With Quote
Old 07-04-2012, 01:49 PM   #2
coltonk
coltonk's Avatar
Re: New Paint, Now to buy rims
sorry first pic is rotated, it shows normal on my computer and i can't get it to rotate on the site itself.
Old 07-04-2012, 02:45 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Here you go.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-04-2012, 03:53 PM   #4
3r!c84
Badass
3r!c84's Avatar
do a 4/5 drop (3inch spindles. one coil cut off stock coilsprings. and flip kit) with chrome coys would look killer!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-04-2012, 05:00 PM   #5
maxxxy
maxxxy's Avatar
Do some KMC Novas with matte black accents!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 07-04-2012, 05:22 PM   #6
coltonk
coltonk's Avatar
thanks randy.
3r!c84 - i do want to lower it more but i don't want to cut anything, everything on the frame has been completely re-done and is brand new. As it is now it rides better than my daily driver.
Maxxxy - Ive never seen those wheels i will have to look into them. Thanks for the suggestions so far tho anything is always a option. I just don't want to spend the money and a week later see another truck with rims i wish i would have gotten.
Old 07-04-2012, 05:24 PM   #7
maxxxy
maxxxy's Avatar
These are them
You have a sweet truck. Keep up the good work!
Max
Max's bagged 81
Old 07-04-2012, 07:14 PM   #8
primrrd
primrrd's Avatar
are you sure the blitz black (a oil based enamel) is compatable with the clear being used?
primrrd is offline   Reply With Quote
Old 07-04-2012, 07:28 PM   #9
broey
Square
broey's Avatar
get the coys.. the boss 338's are already played out. they are like the spinners of the c10 world.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 07-04-2012, 08:03 PM   #10
baclay9
And Coys aren't??? I like both but they are both completely played out on this site. That being said I rarely see them locally.
baclay9 is offline   Reply With Quote
Old 07-04-2012, 09:41 PM   #11
coltonk
coltonk's Avatar
No I'm not certain clear can go with the Blotz Black, I made post asking about using the clear with it on the site and nobody had done it so I figured I would just try it.
I agree on the Boss 338's and I'm leaning more to the Coys because of the Black chrome, I think it would look sick with the semi gloss black
Old 07-04-2012, 11:08 PM   #12
broey
Square
broey's Avatar
yeah black chrome is sweet.
Old 07-04-2012, 11:30 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Are you set on going with 18s and 20s? With such a mild drop the 18's are going to look rather small on front. I suggest 20's all around and stagger your tire height.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-05-2012, 12:12 AM   #14
coltonk
coltonk's Avatar
No I'm not set on staggered wheels. I have thought about 20x8 up front and 20x10 in rear. I have 15x10 on front and back now and with as much tire as I have now the front rubs when I make sharp turns. I def think if I go same size all around I would do 20's tho. All this makes wish I would have dropped it a little more.
Old 07-05-2012, 12:09 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Drop it a bit more before you buy tires. Problem solved..
Articles-
"Refining Sierra"
Old 07-05-2012, 12:19 PM   #16
primrrd
primrrd's Avatar
- what was the issue with the clear? and what type of clear did you use?
the oil enamels of old were real bad about wrinkling under any kind of catalized product, laquer primer, activated 2k primer, etc.
If the enamel was in decent shape and not peeling - i used to use an RM brand waterborne primer to bridge it in jambs and such to avoid complete stripping.
Thus the issue with JDBB.... probably a fine product, but still an oil based enamel and not very compatable with any future upgrade to paint, shiney or otherwise!
Old 07-05-2012, 09:00 PM   #17
coltonk
coltonk's Avatar
ok this may sound like a stupid question, but someone please help me with the "backspacing" on a wheel. the Coys i want offer 4 3/4 ", 5 1/4" inch on the 20x8.5 and 5", 5 1/2" inch on the 20x10 wheels. do i need a particular one or is it all preference and if so what does it change? and what size tire do you prefer to run with the drop i have now with this set up that i mentioned above with the Coys.
thanks in advance
Colton
Old 07-05-2012, 09:02 PM   #18
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Nice!!!
Smoke_Dog is offline   Reply With Quote
Old 07-06-2012, 07:46 AM   #19
BabyBlue
The Peacemaker
BabyBlue's Avatar
4 3/4" on the front will work and definitely 5.5" in the rear. As far as tires I am running these on my staggered 18x8's and 20x10's: 245/45zr18's and 305/40zr20's Goodyear Eagle F1's
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 07-06-2012, 10:01 PM   #20
slinginrods
slinginrods's Avatar
Don't clear over tha oil based paint,hot rod flats would be the choice for a base / clear set up .or just use a flattened clear coat over any color base ( the base coats are flat until the clear goes on that's what makes it shine unless it's a single stage enamel).
slinginrods is offline   Reply With Quote
Old 07-06-2012, 11:11 PM   #21
coltonk
coltonk's Avatar
Babyblue, do u have any pics of this set up? I'm dying to see it.
Old 07-07-2012, 12:55 PM   #22
BabyBlue
The Peacemaker
BabyBlue's Avatar
Plenty of them, although mine is a stepside and sits quite a bit lower than yours but that just means that you shouldn't have any issues at all.
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 07-07-2012, 01:58 PM   #23
broey
Square
broey's Avatar
is that the truck that had wires before? if so I hope you kept those wheels they were bada**!
Old 07-08-2012, 05:36 PM   #24
coltonk
coltonk's Avatar
I like your set-up baby blue. Im def going to do 305 in the rear when I bet my wheels. I will post pics of the truck tonight when I get home I'm on my cell phone now. I picked it up from paint on Friday.
