Shocks for stock ride height 3/4 ton
I'm about to do a brake job on my Longhorn, and while I have it on the lift, I would like to replace the shocks at the same time. I was wondering if anyone had any good suggestions for a reasonably priced shock that would provide a good ride. The majority of the driving is done on roads in town unloaded, but is used to haul heavy loads a few times a year.
Thanks, Zak
71 Longhorn 402, PS, PDB, AC, Tach, Posi 67 SWB 6.0 LSX swap, 4/6 ECE Drop (Work in Progress) 2002 Victory Red ECSB Silverado 5.3 (DD) |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Shocks for stock ride height 3/4 ton
Anyone?
My truck's SPID says "HEAVY REAR SPRING" ('72 C20 w/ rear leaf). I just want stock ride and height. Most of the parts stores websites only have shocks that say "except heavy duty suspension". Does this mean I need a different shock absorber?
Anyone have Monroe Sensa-Trac shocks on a 3/4 ton with the heavy rear springs? |
I would suggest the monroe sensa-trac. I'm using them on my c10 and they work good. If you can get them for your c20 i would give them a try. They are softer when the road is smoother (less shock travel/activity) and firmer with rougher roads, etc.
