Old 05-18-2003, 03:31 PM   #1
Z28Owner
Z28Owner's Avatar
Need some wiring help....
On my 71 truck, I replaced both brake lights and flasher box. I cant figure out why one works and other doesnt. My drivers side turn signals, brake lights and parking lights all work. My parking lights work on Pass side, but no turn signal or brake light. I swapped bulbs and still same thing, so Its not a bad bulb. I have checked all the wiring around the bed its all fine. Could someone fill me in on how or what this could be if you have had the same problems, TIA - Jason
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 05-18-2003, 04:15 PM   #2
TROYLV
could be a wire in the steering column or a bad turn signal switch.
troy wilson
TROYLV is offline   Reply With Quote
Old 05-18-2003, 05:21 PM   #3
Mackey
http://www.geocities.com/chevroletc1070/taillghts.html Go here for wiring layout. Double check the socket outlet, could have a bad spot if the other bulbs aren`t working in it. Then back trac the wiring bed-column. Sometimes it`s just the socket harness.
Mackey is offline   Reply With Quote
Old 05-18-2003, 05:28 PM   #4
71elect
Jason, I had a similar problem right after I purchased my 72'. With the brakes applied and the right turn signal initiated, my left rear brake light would shut off while the right rear light still flashed for the turn signal. After swapping bulbs and checking the wiring and connectors, it all pointed to the turn signal switch in the steering column. Once the switch was replaced all was back to normal.
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 05-18-2003, 05:49 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
check grounds too!!! and the flasher althought the brake light would work then with a bad flasher
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-18-2003, 11:09 PM   #6
Blue Beard
Blue Beard's Avatar
Have to go along with the possible ground.....scrape things or a little sanding to get better ground..........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-18-2003, 11:29 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Not a ground, the parkign light works off the same ground. If the added amprage (which needs better grounds) was a probelm, the parking light would go out and (most likely) not come back on untill the assembly was fiddled with.
It is possable....but not very likely.
I'd investigate the turn signal switch. Try wiggling the lever and even tugging on the harnss where it goes into the column as some one watches the light.
