07-04-2012, 06:03 PM | #1 |
how do I raise front end on 72 truck 1 inch
I have a 1972 C10 2wd and am looking to raise the front end to level it with the rear. What is a cheap and easy way to do so?
thanks! |
07-04-2012, 07:36 PM | #2 |
Re: how do I raise front end on 72 truck 1 inch
you can put blocks in the front springs,CHEAP, you can put in new springs. youcould put bags in the front or air shocks,
07-04-2012, 09:19 PM | #3 |
1" drop blocks in the rear = much easier and same result. (assuming youu're ok with it being a tad lower than stock? ) Prob what I'd do .. just sayin.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
07-05-2012, 12:20 PM | #4 |
I saw a raised truck where the owner put a block between the frame and front crossmember to raise it up, but he told me he had to modify the steering components.
'69 Fleet It ain't yours, if you didn't build it! |
07-05-2012, 12:31 PM | #5 |
I just put Power King Super Traxion II's (7 X 15) on, and it looks great. So Im just looking for an easy way to bring the front end up a little. Sounds like the coil spacers may be the way to go. I take it pretty easy on the truck and just want it to look nice.
07-05-2012, 04:59 PM | #6 |
I've been looking online and can't find anywhere to order coil spacers for my year model....Any suggestions??
07-08-2012, 12:35 PM | #7 | |
Thanks, Chris
Favorite quote: "I'm sick and tired of being sick and tired B¡±@h!" - Drunk guy in one of my accounts Rides: 67 Chevy C10 LWB Stake Bed(in bad shape) 04 Miti Endeavor AWD(wife's ride) 76 Dodge D100 Club Cab(Hand-me down from my Grandfather) |
07-08-2012, 12:49 PM | #8 |
67-72 parts collector,…
Are you talking easy,... as in not disassembling the front suspension?
Belltech makes a 1" coil spring spacer that goes in the lower a-arm cup,... but the spring has to come out.
07-08-2012, 01:11 PM | #9 | |
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
07-09-2012, 03:56 PM | #10 |
I'm not looking to drop my truck at all, but thank you for your advice.
I have been looking for spacers and couldn't find any. I'll look in to Belltech. If they don't work out I can just take them back out and realign. thanks! |
07-09-2012, 04:08 PM | #11 |
Big block front springs maybe?.. that would raise it about an inch
07-09-2012, 06:29 PM | #12 |
Moog spring rates and ride heights
From robnolimit's "make it handle" thread Moog # 6082 722 lbs/in 6 cyl, and light v-8 Moog # 6542 842 lbs/in std v-8 Moog # 6102 1015 lbs/in bigblock, longbed c.s. Moog # 6104 1016 lbs/in 3/4 ton, sits 1/2" higher than #6102 Moog # 6454 1060 lbs/in 3/4t bbc, c.s, 1ton Last edited by 69gmcc10; 07-09-2012 at 06:36 PM. |
