07-04-2012, 08:10 PM | #1 |
Overload Setup Rear Leafs
This is a stock overload pulled from a 70 C/20 Longhorn. The only thing missing is the u bolts. Also included is the stock rubber stoppers. $25 plus shipping.
Thanks, Ray |
07-04-2012, 08:31 PM | #2 |
Carpe manana
Re: Overload Setup Rear Leafs
Ray - Interested...do you know if stock U-bolts will work w this set up? Would be nice in my K20. Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
07-04-2012, 08:39 PM | #3 |
Pete, You will need the stock type u bolt, but longer because of the spacer.
Thanks, Ray |
07-04-2012, 08:47 PM | #4 |
Carpe manana
How much shipped to 87110?
07-04-2012, 09:43 PM | #5 |
Pete, I will get a quote tomorrow.
Thanks, Ray |
07-06-2012, 02:07 AM | #6 |
Pete, Sorry...Called in for work. Quote Fri.
Thanks, Ray |
07-06-2012, 12:17 PM | #7 |
Pete, Its $35 total to ship springs and hood latch. The leafs will go fedex and the latch and brackets will be stuffed in a large flat rate. Grand total is $65 shipped for everything.
Thanks, Ray |
07-06-2012, 12:53 PM | #8 |
Carpe manana
Ray thanks. Pack it up - I'll take the parts as long as the springs are correct for a leaf spring truck (going in my K20). Any chance you have pics of the helper springs installed? Couldn't find any posts on this in a non-coil truck. Send PM with PP address when poss. Will square up later from secure connection at home.
07-08-2012, 11:44 PM | #9 |
Pete, Here's a couple pics. Hard to get with the duallys. You set the spacer on top of your springs and then set the overload leaf. u bolt everything together. Use grade 8 bolts to attach the frame brackets.
