Old 07-05-2012, 12:55 AM   #1
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
67/68 Steering Wheel Trivia
What is the steering wheel in the first pic below from originally? I don't know so it isn't really a trivia game...
I had trouble trying to get my new horn button to work because it seemed too tight against the steering wheel. I bought the steering wheel (that I thought was an original) at a swap meet two years ago and put the factory one from my truck on the shelf. I didn't notice the difference and now I want to know what this steering wheel is out of or what kind of horn button to use with it.
Here is a pic of the wheel I bought and ran for the past year that doesn't have a recessed flange for the outside bend of the horn button to fit into when depressed. The pic below it is my original wheel getting prepped for new epoxy. All other original steering wheels I've seen have that step at the end BUT the one I bought (pic 1) at a swap meet doesn't.
What is this mystery wheel originally out of? Horn delete? It is the exact same size and shape as original except for that missing step at the end.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 07-05-2012, 08:45 AM   #2
Re: 67/68 Steering Wheel Trivia
Hmmm...If it was a bit larger I was going to suggest maybe it was from a newer medium duty that had some other design horn button. But,it's the same size and I have only seen the same type horn button on medium duties. I thought maybe an air horn equipped heavy medium would have a blank. It's not like GM to make a different part for the same purpose,so this is truly a mystery. Can't wait to see what comes out of this. Good thread!
Old 07-05-2012, 09:53 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Could be that because turning the outer area for the horn button is an extra step and therefore extra cost they made some for vehicles that didn't require a horn (just a thought).
If it's exactly like your original and in good condition a good machine shop could duplicate that outer step for you.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-05-2012, 10:00 AM   #4
68panelman
68panelman's Avatar
Theres probably a part # on the bottom. That could help you out, but you will have to pull the wheel.
68panelman is offline   Reply With Quote
Old 07-06-2012, 01:26 AM   #5
thecatseye66
'68 C-20 396 CST CC
You rock panelman. Looks like part number 9745762.
How do you decipher that?
Old 07-06-2012, 03:20 AM   #6
SS Tim
SS Tim's Avatar
Looks to be a '67 Nova (Chevelle & Elky) three spoke wheel.
http://www.classicindustries.com/nov...s/9745764.html
http://www.stevesnovasite.com/forums...p/t-90783.html
SS Tim is offline   Reply With Quote
Old 07-06-2012, 01:43 PM   #7
thecatseye66
'68 C-20 396 CST CC
Originally Posted by SS Tim View Post
Tim,
I can't find anything to confirm that anywhere. In fact, the Nova/Chevelle wheel in the Classic Industries link above is part number 9745764 but this wheel is 9745762.
Chris
Old 07-06-2012, 03:23 PM   #8
SS Tim
SS Tim's Avatar
Originally Posted by thecatseye66 View Post
Tim,
Chris
Well, I don't quite know what to say. Where did you look? The second link I posted had the primary information that lead me to the '67 nova application. A quick cross check showed the ..64 P/N as a '67 nova. Since I don't currently have a pass. car parts book covering these cars its up to you to do the leg work. A deep search of my truck parts sources 10-60 showed similar 63-68 and tilt '70 applications but were hundreds of numbers or more off from your target. So this seems to be a valid lead. GM P/N typicaly use the last digit for similar handed parts or running changes. Since there wouldn't be a LH vs RH steering wheel it is probably a color difference. Classic is going to list a part number for their products using the last or most common known P/N. In any event you are very close. Try to dig up access to parts catalog ending in '67 to check and not a parts book that goes back to '67. The later a book is printed (by GM) the more superscessions and deletions there are.
