07-05-2012, 02:48 PM | #1 |
rubber or poly bushings?
I am in the process of changing all of the bushings out on my 67.
I wanted to get some feedback as to which type bushing I should go with. I hear that the poly is hard and squeak. I hear that the rubber ones break down, crack, and deteriorate. So I wanted to get some opinions here before I make my purchase. So what do you think?????? |
07-05-2012, 03:27 PM | #2 |
needs more $$$
Re: rubber or poly bushings?
I'd do stock rubber for squeek free use alone. Lots of different opinions out there, so it's based on your driving style and doing what you can to not have them squeek if you go poly.
I have poly body mounts (PO installed)...they squeek. I sprayed them with white lithium while loosening and jacking up the body, but I doubt that will last long.
1970 2wd Blazer |
07-05-2012, 03:45 PM | #3 |
Charlie Daniels w/ a Tq Wrench
Rubber=usually quieter, less harsh/less vibration transmitted
Poly=Tighter handling, last longer I guess it all comes down to what you are after. In the majority of bushings I have changed, I have gone to poly. I have never had an issue with squeaking, but I lather mine up with grease before installing, although I have been around others and heard their squeaking poly bushings.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
07-05-2012, 04:26 PM | #4 |
My solution. Zerk fittings do wonders. Poly has worked great on all my vehicles otherwise try looking for polygraphite bushing kits or use graphite lube as well.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-05-2012, 07:28 PM | #5 |
I say polyurethane, as they will last longer, and have always had good luck with them. There are pro / cons to everything though.
We are a direct Prothane dealer.Their products that are black in color have a slight hint of graphite in them. Prothane Products for 67-72 C10 |
07-06-2012, 01:24 AM | #6 |
Rubber will flex a little so it does help smooth out the ride but that flex can hurt handling and it wears out faster.The poly ones are hard so they last a long time flex almost none if you keep them lubed right they don't squeak that bad as some make them out to be.If its my daily driver normal truck i would use rubber if its a weekend ride or trying to make it handle better then i would use the poly ones.
07-06-2012, 09:02 AM | #7 |
Daily driving with urethane bushings isn't harsh at all. Your springs and shocks are supposed to do the work, not the bushings. If you ever carry any weight, tow or like improved handling, urethane is the way to go. If you lube them properly during installation, they don't squeak.
07-06-2012, 10:27 AM | #8 | |
Happy to be here
07-06-2012, 04:11 PM | #9 |
Thanks to everyone who chimed in with feedback.
I decided to go with the ones mentioned with Pro Performance. Thanks again guys |
11-25-2012, 09:45 PM | #10 | |
Gary 1971 K5 Blazer 350 V8 |
11-25-2012, 11:40 PM | #11 |
Grandpa in the rustmobile...
Glad to hear good reviews aabout stuff I just bought
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-26-2012, 01:27 PM | #12 |
11-27-2012, 12:45 AM | #13 | |
Quick question I noticed that prothane has different part number for 4WD and 2WD trucks. But only one part number for the full kit. Is it universal or is it 2WD or 4WD specific. I have a K5 (4WD) and want to make sure I get the right parts
11-27-2012, 02:05 PM | #14 |
That total kit is for the 2wd, but I can put together a kit for the 4wd, no problem. PM Sent.
Travis |
