Old 07-05-2012, 04:53 PM   #1
b2948kevin
b2948kevin's Avatar
1.75" Water Neck for a Chevy 350?
Anyone know if anyone makes a thermostat housing (water neck) for a Chevy 350 that has a 1.75" nipple? All of them that I see are 1.5, but my upper radiator outlet is 1.75", so I am always looking for a 26" long 1.5"x1.75" upper radiator hose, which I can never find.
Am I doing something the hard way?
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
Old 07-05-2012, 11:42 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 1.75" Water Neck for a Chevy 350?
One solution would be to use a Gates p/n 26391 reducer. Here’s a link showing one for about 5 bucks. If you click on “More info” it shows a close up. This would allow the use of any hose the correct length:
http://www.rockauto.com/dbphp/x,cata...TES_26391.html
Another option would be to show the specs on the following page, and ask your local parts store to check the manufacturers catalog and see if the same 1.5” x 1.75” combination hose is produced 6” longer.
http://www.napaonline.com/Catalog/Ca...254_0117350901
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-05-2012, 11:47 PM   #3
b2948kevin
b2948kevin's Avatar
Hey Mark, thanks a lot for the response! I hadn't even thought about a reducer. I think I will go that route because it's cheaper, and also because there's a higher likelihood that I'll be able to reuse this with another hose like what I have in a pinch. This will give me max flexibility.
Thanks again!
75 Harley FLH
