Old 07-05-2012, 06:31 PM   #1
king-918
king-918's Avatar
does anyone run 1/2 inch push fittings on 200 psi?
Leaks? Secure? What type of line?
king-918 is offline   Reply With Quote
Old 07-05-2012, 07:03 PM   #2
Pro Performance
Pro Performance's Avatar
Re: does anyone run 1/2 inch push fittings on 200 psi?
Just make sure to get good fittings, cut the line very square, and you will have no leaks. I have done a number of systems in 1/2" using PTC fittings. We sell the DOT approved fittings... although more $$.... they don't leak. Also go with DOT approved air line, for durability reasons.
Pro Performance is offline   Reply With Quote
Old 07-05-2012, 07:14 PM   #3
broey
Square
broey's Avatar
x2
Squarebody Syndicate
broey is offline   Reply With Quote
Old 07-05-2012, 08:02 PM   #4
king-918
king-918's Avatar
does the hose need an insert or just a simple push?
Old 07-05-2012, 08:07 PM   #5
Pro Performance
No insert, just push the air line into the connector all the way, and make sure it is fully seated.
Old 07-05-2012, 08:27 PM   #6
king-918
king-918's Avatar
the real question is then how much for a Bag of fittings? doing the front of my 86 c-10 for now.
Old 07-05-2012, 08:59 PM   #7
Pro Performance
Let me know what you need exactly.
http://www.azproperformance.com/Air-Fittings/
Old 07-06-2012, 12:23 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
Just my $0.02 here, but are you dead set on 1/2"? I have all 1/2" lines on my Blazer and it's way too fast and was kind of a pain to route in tight bends. If I ever did this all over, I'd definitely do 3/8" lines. Perfect speed, easier line routing and all the fittings are a little cheaper.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 07-06-2012, 12:59 PM   #9
king-918
king-918's Avatar
Thanks this is my first build and was curious about everything also jumped with both feet in
Old 07-06-2012, 01:11 PM   #10
jimmydean
jimmydean's Avatar
I did 1/2" on my '69 and it was TOO fast. I ended up putting dump and fill adjusters to control the flow. It was nice to be able to dial it in, but I will do 3/8 max from now on.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-06-2012, 01:36 PM   #11
king-918
king-918's Avatar
i was thinking if its too fast i would just keep reducing the dump? you 1/2 to 3/8 or 1/4.
Old 07-06-2012, 01:41 PM   #12
jimmydean
jimmydean's Avatar
The fill was too fast, also. The dump adjusters (one on each of the 4 dump valves) also worked as a muffler that my neighbors appreciated.
I had 2 feed lines, so I only needed 2 fill adjusters.
These on the fill side:
[IMG]http://*************/files/1-2_PTC_Valve_Fill_Controls.jpg[/IMG]
These on the dump side:
[IMG]http://*************/files/1-2_NPT_Valve_Flow_Control.jpg[/IMG]
<edit> It was nice to dial in the speed I wanted, but at 1/2" it was all up or all down with the hit of a button. I swear it jumped 4" off the ground the first time I hit the all up switch after install.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-06-2012, 01:46 PM   #13
tubbedII
needs more $$$
tubbedII's Avatar
I have flow controls for mine now. I'm pretty sure I got them all from AVS since they are vendors here on the board. The 1st set go in line off the tank and has a little dial on them to adjust the speed of the fill (1 for each line). The other set goes on each dump valve and also has a dial on them to adjust the speed of the dump, but also has a muffler on them to quiet it down. The mufflers were $8 a pop, but the flow controls for the fill were a little more like $15 a pop or something. My dumps are all right at my rear tire, so it's crazy loud and scares most who aren't ready for it, so the mufflers should be a good addition.
<edit>
You type fast jimmydean! That's the same set up I have for the Blazer. At about 130 PSI from full dump to full lift right now, the front tires do come off the ground a bit...at 200 PSI I bet it'd get a couple inches even with the 22s...not at all what I was going for.
On that note, to King-918...my bags reach full lock both front and rear at around 85 PSI (I have Doms all around). I don't think you're going to need a 200 PSI pressure switch.
1970 2wd Blazer
Old 07-06-2012, 02:50 PM   #14
king-918
king-918's Avatar
<edit>
I have a 185 psi switch wanted to swap out for 200, psi switc
H, but maybe not now
Old 07-06-2012, 02:56 PM   #15
Pro Performance
If you run a 200 PSI switch, you just get more storage in the tank for when you do lift the vehicle up. Although the bags may not take 200 PSI to get to ride height, it is nice to have as much air storage as possible.
Old 07-06-2012, 10:31 PM   #16
king-918
king-918's Avatar
200 PSI it is!
Another question? Why does my valves and tank say 1/2" NPT but when i got my connectors the valves and tank are bigger than my connectors?
Old 07-07-2012, 01:32 AM   #17
Pro Performance
Looks like you got 3/8" NPT fittings. The place should exchange them out if you ordered 1/2" NPT, and got 3/8" NPT.
Old 07-07-2012, 01:36 AM   #18
king-918
king-918's Avatar
On 1/2" NPT should the O.D be 3/4"? Because mine are on the bags, tank, and valves
Old 07-08-2012, 11:17 AM   #19
texastrendz
NPT is measured I.D. The inside dimenson of the fittings you will need should measure 1/2 inch. If i remember correctly the O.D. is roughly 3/4 inch on 1/2 NPT fittings.
texastrendz is offline   Reply With Quote
Old 07-08-2012, 11:45 AM   #20
king-918
king-918's Avatar
I went to the hardware store and was kind of going with that thought.
Thanks!
