Pick'n up the pieces!
Rookie driveshaft question
I have a short 70 frame with 350 on front towers with a 700r4 behind it. I did not have a drive shaft with the pile of parts that I started out with. I went to the boneyard a got a drive shaft out of a late 80 swb pu that had a 700r4 in it. I knew to would have to shorten the shaft, but forgot about the pinion yoke being different. Should I get an older drive shaft and shorten it or can i use the one i have by letting them weld a different yolk to the rear that will match the 71 rearend that i have with the external snap rings? Also does anyone have the same set-up that i do, if so what was your center-to-center measurement? Any help appreciated. Learning as I go!!! Danny
Fabricate till you "puke"
You can opt for a conversion U joint to match the parts you have. Just talk with driveline service, & they will set you up. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
