5.3 cruise control wiring
I have been installing the wiring for my 5.3 in my 72 pickup close to being finished. I have a later model turn signal/cruise control with a yellow, red, green, and black wire. The harness has a blue, light blue, gray, and gray/black wires. The classic instruments has a speedometer signal interface box that has a connection for a cruise control. Does anyone have any idea how to wire this.
Thank you Ken |
Re: 5.3 cruise control wiring
What kind of cruise? Factory or aftermarket? DBW or DBC? Look here.... http://67-72chevytrucks.com/vboard/s...d.php?t=511477
If you have other questions just ask. Posted via Mobile Device
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
The cruise is a latter factory one it is not supposed to need the relays to work. I need to know how to hook up the wires.
This is drive by wire
#5 | |
I found out my problem my used indicator/cruise control is a replacement Dakota Digital I will have to wire it with relay's to reverse the direction of the switch's. Thank you for the help.
