Old 07-05-2012, 11:32 PM   #1
1rusty72
Help needed please! 1997 Chevy Tahoe A/C weak airflow out dash vents?
Hello,
I have a 1997 chevy tahoe with weak air flow through vents. It's almost like the selection door is stuck in the half position when selecting any of the settings floor, dash vents, defrost....the blower motor sounds strong just acts like it is restricted. Does anyone have any suggestions? I know the control panel works in all positions and it does go through the different positions when selecting just weak air flow coming out. Any help would be much appreciated. Thanks
1rusty72 is offline   Reply With Quote
Old 07-06-2012, 06:29 AM   #2
speedygonzales
speedygonzales's Avatar
Re: Help needed please! 1997 Chevy Tahoe A/C weak airflow out dash vents?
Is there a lot of air coming out the feet and defrost locations?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 07-06-2012, 08:57 AM   #3
1rusty72
Yes, air does come out feet and defrost when selected. Air blows the same through all selections.
Old 07-06-2012, 09:59 AM   #4
Red88
Red88's Avatar
May be that the evaporator is clogged. Take a look at this from the FAQ.
http://67-72chevytrucks.com/vboard/s...38&postcount=6
'88 K1500 Scottsdale
5.7 TBI, 5spd MG5
Red88 is offline   Reply With Quote
Old 07-06-2012, 04:26 PM   #5
speedygonzales
The problem is with the selector doors or something having to do with them if you have lets say the front vents in the dash selected and the feet and defrost is also on.
I believe you are getting full air flow just that it's coming out of too many locations at once so it feels weak.
BTW the feet and defrost location is default to many vehicles that loose selector door control. That way your body and the windshield will be ok till the problem is corrected.
I think the first thing you should do is get a visual on the device that moves the doors to see what it is doing. I had the problem with our durango where the loop that rotates and moves the doors had fallen off it's mount cause a screw backed out. Screw tight with loctite and all was good.
If the door mechanism isn't moving, you have to see what moves it. In the case of my old Camaro, it was vacuum powered dash pots. In the case of the durango, it was electric motors. Then see if they are getting the source that powers them. (Either vacuum or dc voltage).
If they are and they aren't moving the problem is simple. If they aren't getting source, then you have to see why. Start with the controls.
Pride and joy
Old 07-07-2012, 07:50 PM   #6
gregory5000
Could be a vacuum leak. My 2002 Olds Silhouette had that to happen and it was a vacuum leak.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 07-08-2012, 11:11 AM   #7
hatzie
Moderator
hatzie's Avatar
The control doors run off electric motors. Many GM vehicles have problems with the gears in these motor units.
The 1995-2000 dash control unit is not that good either.
I've replaced both on my GMC.
It's unbelievable how much dirt gets caught by the condensate and stays in the evaporator. A heater/AC box filter would've been real nice. I rinsed mine for quite a long time before the water ran clean out the drain. The airflow didn't appear to increase but the vent temps dropped noticeably.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-23-2013, 05:10 PM   #8
ChevyCruizer
17's too small
ChevyCruizer's Avatar
My 99 Suburban had that problem. The air was always weak coming out of the dash vents but when I selected defrost or floor it was much stronger. I bought a new electric door motor, but when I got under the dash to replace it I found that the plastic/spring loaded blend door arm had become disconnected when a part of the plastic broke. A trip to the local pick a part yard had me back in business. For me it was the door that is located near the gas pedal.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
