Old 07-06-2012, 12:36 AM   #1
SWAG
What are the differences between c10, c20 and c30 frames?
...and also are there frame differences between C and K trucks?
Mostly I'm curious about frame size / frame thickness, pictures would be nice. I tried searching and couldn't find anything because there were way too many threads.
Also can a 1/2 ton frame safely handle 3/4 ton loads? I have hauled 6200 lbs / 300 lbs tongue with another 300 lbs in the bed with my C10 over the mountains with no anti-sway bar, she was nearly bottomed out but I didn't have any trouble.
SWAG is offline   Reply With Quote
Old 07-06-2012, 01:30 AM   #2
andrewmp6
Re: What are the differences between c10, c20 and c30 frames?
I have heard people say the 1/2 and 3/4 ton are the same frame but the 3/4 ton has extra bracing to the cross pieces and the 1ton is its own frame.If it was me i would look up what your truck can tow and don't go over it.They do sell a helper air bag that goes inside the rear coil springs that can level your load out for you.As long as you tow smart you should be ok just pray d.o.t. don't pull you over and get out there scales.
andrewmp6 is offline   Reply With Quote
Old 07-08-2012, 12:51 PM   #3
clb1024
clb1024's Avatar
Also if you are planning a frame swap to be able to tow more, check your state laws about frame swapping. If you just swap it and get stopped and are found to be overloaded, its one heck of a fine. Our 1/2 tons are only rated to tow 3,900-5,800 lbs. I would not recommend towing more than that. Just my $0.02 though.
Thanks,
Chris
Favorite quote: "I'm sick and tired of being sick and tired B¡±@h!" - Drunk guy in one of my accounts
Rides:
67 Chevy C10 LWB Stake Bed(in bad shape)
04 Miti Endeavor AWD(wife's ride)
76 Dodge D100 Club Cab(Hand-me down from my Grandfather)
clb1024 is offline   Reply With Quote
Old 07-30-2012, 11:10 AM   #4
Charlie1c
Why not just move the car back a little on the trailer and let the trailer support the weight?
Charlie1c is offline   Reply With Quote
Old 07-31-2012, 02:02 AM   #5
andrewmp6
Its not the weight balance its the total weight is the problem.If you try to haul more weight then your truck can handle the trailer will end up driving the truck which is never fun and can cause wrecks.
Old 07-31-2012, 10:21 AM   #6
Charlie1c
It actually is the weight balance that is the problem in the picture. And there is a huge difference in "rolling" and "static" weight. Equip the trailer with brakes and load it correctly and it will take care of itself. I have seen 1/2 ton trucks licensed at 18,000 lbs. I have also seen Surbabans licensed as cars and pulling 18,000 lbs. As long as you license your vehicle to pull the weight you desire DOT will not be a problem. At least not in Missouri.
Old 08-02-2012, 12:17 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Way too much tongue weight on the truck in that picture.
Air bags in place of coils would do a great job of solving this issue,... but you still have to position the car on the trailer in the correct spot.
Keith
Convert to disc brakes.
