07-06-2012, 01:56 AM | #1 |
Heater core shut off valve installed
Today I installed a shut off valve in my heater line. Even with all my heater controls turned to the off position I could still feel a lot of heat in the cab.
This job take's all of 5 minutes to complete if your truck is cooled off. I went to Autozone and asked for the valve. It fits 5/8 hose, and some hose clamps. Find the hose that runs from you engine to the firewall, cut it and install the valve tighten the clamps and your done. Make sure to replace any water/coolant that is lost due to cutting the hose. Problem solved no more heat in the cab until I want it!!
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-06-2012, 01:58 AM | #2 |
Re: Heater core shut off valve installed
Here is what it cost me.
07-06-2012, 10:03 PM | #3 |
Does it matter if you install the valve into the upper or lower hose? Coolant enters the upper hose and returning from the bottom hose, right?
I have another silly question for you guys... I have notice that some trucks have the plastic housing on the firewall for the AC components. I am guessing that some trucks (such as my 1984) have the components within the inside of the cab??? What was the reason for the change? Is this something that they changed on the later model trucks?
1984 C20, 454, 4 speed named "Gold Member" |
07-06-2012, 11:32 PM | #4 |
looks like yours might have an aftermarket air conditioner?
Most squares without the big case on the right side of the firewall were Non-AC trucks (the heater core is in a case inside and under the dash, Stock ac has the split case and big accumulator dryer on the rt side of the firewall. you have a sanden compressor (good unit) but your 84, if ac equipped from factory should also have a flat round (a4) compressor on the lt side of the engine. What does the ac on the inside look like? is it an "under dash" unit? |
07-07-2012, 12:37 AM | #5 |
I wish my truck had a Non A/C cab. As far as the hose question. The upper hose is 5/8 and the lower is 3/4. The valve I got from the parts store had 5/8 barbs on it. if you could find a valve with 3/4'' ends on it, that would work just fine.
Now if you Block off the lower hose It may be possible for the water in the heater core can still heat up????? I don't know really. The upper hose is the most common way to do this. Block off the hot water before it even gets to the Heater core.
07-07-2012, 11:00 AM | #6 |
I've been thinking about doing this as well. There isn't a need to run a bypass?
07-07-2012, 12:28 PM | #7 |
just needs it on one side. just needs to stop the flow. did this to my truck a few days ago. honda and toyota use these for heater controls.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-07-2012, 07:44 PM | #8 |
Nope no need to bypass. Every once in a while, while your under the hood open the valve to let the water flow for a little bit then close it back off. Thats just what I do.
07-07-2012, 08:37 PM | #9 |
Moderator
A1 and B1 chassis VW used a cable operated valve. I've thought about adding one to my CUCV.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-07-2012, 10:19 PM | #10 | |
I am going to install one of these shut off valves soon.
07-08-2012, 11:34 AM | #11 |
Another Day, Another Dollar
I'm just throwing this out there but, It seems to me that you should always allow a bit of fluid flow through your heater core or it will prematurely rust out. Shoot me down if you don't agree but I wouldn't want the same fluid sitting in there for half the year.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
07-08-2012, 11:57 AM | #12 | |
All of my AC equipped early 70's vehicles have a factory heater control valve. It runs off a vacuum line so it's open only when you turn the heat on. This is done to keep the hot coolant out of the heater box while running the AC unit (works more efficiently) Different control valves mount different ways. Some of mine are mounted on the inner fender and the hose is simply cut, and a vacuum line runs to the heater controls. My 71 nova is my favorite style, as it actually screws into the intake manifold and acts as a control valve and hose nipple all in one and makes for a much cleaner looking install with one piece of hose. If your truck didn't have one originally (I guess GM eliminated this feature at some point??) Did you ever think of adding a factory one with a vacuum line? I wouldn't think it would be hard to do and you wouldn't have to keep popping the hood and turning a valve all the time. |
07-08-2012, 12:54 PM | #13 |
Just my uneducated $.02, but I don't see why coolant staying in the heater core would be a problem unless you had bad coolant and contaminants precipitated out to the bottom of the heater core. I understand that the moving coolant has a flushing effect on the radiator cores, but since it ultimately moves out of the heater core during the winter it seems like that would not be a problem. You could alternately just open the valve once a month and let it flush. Sometimes my truck would sit for a month while I was driving my other vehicle and I saw no adverse effect on the heater core (however, the effect on old gas sitting in the carburetor caused very damaging varnish formation.
I still am curious about the bypass issue and if installing a shutoff valve in just the input line to the heater core would have any adverse effect. |
07-08-2012, 01:02 PM | #14 | |
07-08-2012, 01:57 PM | #15 |
I have Never seen a valve from the Factory on any of my Squares. I install these valves on all of my trucks. I am under the hood a lot checking things like oil and stuff and I just open the valve for a few minutes and let the water flow. I have only had one heater core fail on me but I chalk that up to being a nearly 40 year old truck.
Secondly LOL, I hate vacuum lines and one less line makes me happy I would like to see a picture or link to a factory installed valve as I have never seen one.
07-08-2012, 05:59 PM | #16 | |
Hang on and I'll find a pic of one of mine.... |
07-08-2012, 06:16 PM | #17 |
Here's one of my 72 blazer with a factory heater control valve. Hard to see in the pic so I circled it. Vacuum line T's into the main line for the heater control vacuum door. So it opens the valve when the heater is turned on. Very simple setup.
07-08-2012, 06:17 PM | #18 |
Well shucks, I suck at computers and the circle didn't show up.
Take a close look at the inner fender, you'll see the small circular gold cad plated vacuum pod that the heater hose runs to. I was lucky on this truck that it had this version of the valve, because the LS engine doesn't have an intake port for it like the old cars did. The other version of this valve screws right into the intake manifold where you would normally see a heater hose nipple. One reason they are seldom seen anymore is that when they started leaking, rather than replace them people would just discard them. As far as I know they were always on the AC equipped cars/trucks. Non AC vehicles didn't get it. |
07-08-2012, 06:38 PM | #19 |
That's pretty cool Ive never seen one. I wonder if they stopped using them in the Squarebodys?
VERY clean LS Swap!
07-08-2012, 06:50 PM | #20 |
Squarebodies endured a rather long production (70's-80's-90's). I have a 79 454 1 ton with factory air. I can't remember if it has one or not, I'll have to go look but I'm betting it does. I should know I've owned the darn thing 15 years and just tossed and 502 in it. Memory sucks when you get old,,,,lol.
I know GM was still using them on cars in the 80's, not sure about trucks. I'm pretty sure once things went electronic there was no need for these control valves anymore. I'd have to investigate it a little further as I never gave it all that much thought until now, and as I mentioned, most of these were removed and never replaced (people didn't want to deal with them I guess not knowing it would affect the AC efficiency) so unless you can look at an original unmollested vehicle it's hard to say whether it would have had one. |
07-08-2012, 06:51 PM | #21 |
Hey I just noticed the circle is there now,,,wasn't before though.
I did it right |
07-08-2012, 07:07 PM | #22 |
My 85 C20 factory air burb never had a heater control valve (Been in the family since new). Though they do benefit from installing one.
07-08-2012, 07:23 PM | #23 |
Now here is a good example. I don't know where the cars may have differed from the trucks, and this is starting to get into the electronic age too.
07-08-2012, 07:51 PM | #24 |
The G-bodies used them till '87, B-body till '90. Im pretty sure Square's dont. I think it has alot to do with the evaorator/heater core case design.
07-08-2012, 07:55 PM | #25 |
Ah there ya go, probably right in that the design of the case had something to do with it. I knew the G-bodies still used them in the 80's, my fathers 81 and then 86 both had them.
