Old 07-06-2012, 04:07 AM   #1
aussiejohn
1964 El Camino
G'day,
I own a 1967 GMC pickup and a friend has just bought a 1964 El Camino and needs some parts for it. If this is not the right place, can anyone tell me what is the best Forum for Elkys please? He has been to a few supposed El Camino sites, but they mostly seem to cater for the Chevelle coupe, rather than the "pickup".
He needs a wiper motor mainly, are these interchangeable with any of our trucks?
We're in Melbourne Australia, so that makes everything just a little bit harder when you need parts or information.
TIA.
Regards from Down Under.
aussiejohn.
aussiejohn is offline   Reply With Quote
Old 07-06-2012, 04:13 AM   #2
MikeS.
MikeS.'s Avatar
Re: 1964 El Camino
Aussiejohn, Welcome to the board. I can't help with your question but I can say G'day mate! I won't put any shrimp on the barbie but I'd throw on a prawn or 2 for ya. Holler over to my mate Tony over Perth way would ya?
Someone knowlegable will be alonng soon, it's 4am here on the East cast, most of the yanks are sleeping.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-06-2012, 05:38 AM   #3
losthope
losthope's Avatar
Re: 1964 El Camino
heres some I found some they have different number of speeds and pictures then others so you should double check which one you need :
autozone has 1 speed and 2 speed motors:
http://www.autozone.com/autozone/par...mString=search
$68 1 speed motor/no washer pump:
http://www.partsgeek.com/catalog/196...per_motor.html
$99 1 speed:
http://www.autopartswarehouse.com/de...QQA140119.html
1 speed motor:
http://www.opgi.com/p/car-care/10910/7/CH28544.html
2 speed motor:
http://www.opgi.com/p/car-care/10910/7/CH20280.html
2 speed motor:
http://www.elcaminostore.com/el-cami...pump-1964.html
2 speed motor:
http://www.ss396.com/mm5/merchant.mv...de=WIPERSYSTEM
hope this helps
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 07-06-2012, 06:19 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 1964 El Camino
The EL Camino is acutally on the General Motors A-body platform. 1964-1967 then 1968-1972 are the two major age groups. They share parts with Chevrolet Chevelle / Malibu. Pontiac GTO / Le Mans. Also Buick, but I can't remember the models...
http://www.chevelles.com/ is a great resource and there are some Aussi folks on the forums too...
Rich
1972 K5 Blazer CST Click HERE
Old 07-06-2012, 08:27 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1964 El Camino
yep, elcamino is chevelle , so almost anything you need for a 64 elcamino will interchange with a 64 chevelle, the 64 elcamino is basically a 64 chevelle wagon with no roof!
obviously there are some elcamino specific parts: bed / door tops/roof, but you will be suprised what is available for these in the aftermarket. order up some chevelle/elcamino catalogs from year one, and original parts group.
btw, to clarify; this is a pic of a 64 elcamino, is this what your friends car looks like?
Old 07-06-2012, 09:11 AM   #6
aussiejohn
Re: 1964 El Camino
Thanks a lot guys, I'm sure that we're headed in the right direction now.
jonz, that's exactly what it looks like, only metallic green. It has a worked 350 with twin four barrels on an Offenhauser manifold with progressive linkage.
losthope, thanks for the great leads. We'll follow that up ASAP.
aussiejohn
Old 07-06-2012, 01:38 PM   #7
jimmydean
jimmydean's Avatar
Re: 1964 El Camino
Oooh, I love me some early El's. Yes, Chevelle/Malibu they are, only slightly more useful thanks to the bed.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
