Old 07-06-2012, 09:49 AM   #1
McCoyAZ
McCoyAZ's Avatar
Swapping grille from a 61 to a 64 ?
Can one of you walk me through the process of swapping out a 64 grille for a 4 light 61 grille please?
Since the supports are different, what will be involved in the swap?
Details would be nice.
there was a thread somewhere about wiring the 4 light grille with modern lights and relays?
McCoyAZ is offline   Reply With Quote
Old 07-06-2012, 09:55 AM   #2
losthope
losthope's Avatar
Re: Swapping grille from a 61 to a 64 ?
4 lamp relay thread:
http://67-72chevytrucks.com/vboard/s...elay+headlight
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 07-06-2012, 06:29 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
From what I’ve read, the only difference in grille supports is the mounting holes for the headlight brackets which attach the grille to the truck. Just pull the later grille, hold the earlier version in position, mark and drill the holes, and bolt in place. This drawing shows the location of the attaching bolts on the 1960-61 grille:
A note on the wiring - everything from the radiator bulkhead back to the dimmer switch is the same regardless of whether the truck has 2 headlights or 4. The difference in the harness begins at the radiator bulkhead connector forward. Plugging in a 4 headlight grille harness will instantly connect the extra two headlights. Installing relays per the diagram are highly recommended however, along with upgrading all wiring to at least 14 gauge throughout. Original harnesses are severely undersized with 18 and 20 gauge wiring on the low beams and grounds respectively.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-06-2012, 06:36 PM   #4
McCoyAZ
McCoyAZ's Avatar
Thanks guys you are more than helpful.
Old 07-06-2012, 08:01 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
your 2 top outside holes are the same, I just bolt it on there, and the shoot a little spray paint over the other holes so you can find where to drill
