![]() Join Date: Feb 2001
Starter will not disengage!
Trying to get a parts truck to run that I just got in. When I turn the key to "start", the starter engages but will not stop, even with the key turned off. I have to run up and yank the negative battery cable off to get it stop. Is the problem in the switch or in the starter? Thanks for any help.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
Re: Starter will not disengage!
I had the same problem, in my case it was the starter.
1969 Chevy K20 Custom Camper 350, 4sp, 33's High on plans, Low on funds |
#3 | |
Sheetmetal Psycho
I ended up buying a new starter. I was told that something internally was burned out. I tried a new solenoid before the starter but same issue.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
![]() Join Date: Jul 2001
I had the same exact problem several years back with a new rebuilt starter. I took it back and got another and it was fine.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
![]() Join Date: Apr 2005
Sounds like a bad starter solenoid...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
mine was doing the same thing the other day but ive got a ford type silinoid , bought a new one and that was it..maybe thats it
Thanks for the input guys. I was hoping is was just the solenoid, but I may replace the starter. I don't like laying on my back in 97 degree weather!
JQ
Its better than laying in the snow or ice to do it
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
I had a 67 that did the same thing, turns out that the pinion stop was missing.
see diagram: ![]() |
