Old 07-06-2012, 04:03 PM   #1
Rat66
Rat66's Avatar
Airbag help needed
Hey guys. I just bought a 66 C20 Fleetside. The suspension in this thing is so bad I swear it is the factory shocks and springs. It is dangerous to drive on the freeway and is basically useless as a truck.
I have over the years learned many lessons when it comes to lowering/lifted vehicles. You can never go too high or too low. With that said, I have wasted a ton of money on suspensions only to end up replacing it later to go higher or lower. And sometimes maybe even again. I am trying to plan out this truck a little better. I want to be sure that each stage in this project will get me to where I ultimately want to be. That goal is to one day be bagged and laying the frame.
Now, my next stage in this project is to do something with the suspension. I have to make it safe and useable. I would like to buy bags for the front and rear as well as a cheap set of shocks (disposable). Once the bags are installed it would basically be used at roughly stock height until I am ready to tackled the front spindles and notching the frame. So I am looking for bags that will work for now at a stock height but can ultimately lay frame down the road.
I came across this link that basically looks like what I will want to do to start.
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
After looking through that post I came across this kit at ***************** for the front. You can get the airlift or slam bags with it. http://*************/-63-87-fullsize-...ag-bracket-kit. I don't know the difference between the bags and/or compressors, etc. Can you guys help me figure out what I am looking for? Kits? Brands? Obviously looking for the best value for my $$$. I am new to bags/air management systems and really would like to know what to look for and what to stay away from.
Thanks for your advice!
Shawn
1966 C20 Long Bed Fleetside
1988 Jeep YJ Hybrid Monster
Rat66 is offline   Reply With Quote
Old 07-06-2012, 04:20 PM   #2
jimmydean
jimmydean's Avatar
Re: Airbag help needed
That is one of the best write ups on this site and is exactly what I used when I bagged my '69. You can get everything you need from a site vendor here. Check out the suspension marketplace and poke around the suspension forum.
One of the vendors posted an air management kit with manual valves for under $600. Add some brackets, and 4 bags, you are set.
Welcome to the forum.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-06-2012, 04:21 PM   #3
jimmydean
jimmydean's Avatar
Marketplace
Suspension Forum
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-13-2012, 01:46 PM   #4
Rat66
Rat66's Avatar
Thanks jimmydean for the info. I found this post http://67-72chevytrucks.com/vboard/s...d.php?t=442745 on the marketplace. Would these be a good choice? I emailed him but never got a reply back.
I read in another post that someone had better luck/ride with the 2500 bags over the 2600 bags. I am wanting the best ride as well as the ability to haul and lower if needed.
Thanks again!
