05-18-2003, 07:31 PM | #1 |
How do i change my turn signal switch?
Gotta do it. But don't know how. Any pointers?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-18-2003, 08:11 PM | #2 |
Inline 69
disconect the battery first,{horn will probably blow a few times during dis-assembly}.Pull steering wheel,,use a puller its alot easier than trying to beat it loose with a hammer.Under the column youll see 2 little tabs.bend them out and the cover under the column will come out.youll also have to take dash out to connect new plug.it sits on top of column.remove screw that holds signal lever{dont forget to re install before u put the steering wheel on}unscrew the plastic assembly,pullout old harness,plug in new.Iwould try the new harness BEFORE you reinstall everything,,,
