Old 07-06-2012, 11:18 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
TH350 OOzing
There's some seepage at the shifter rod....where it goes into the body of the trans.
I went to Napa today and they ordered the "part"...$1.69.
I can't find a schematic anywhere....I'm hoping that it goes in from the outside and that it's something I can do......
with my limited brains and limited patience.
For a long time, I was "chasing" a brake fluid leak. Right now, there are only two fluids in the truck...oops...three including the differential.
So, as I chased an elusive brake fluid, the trans fluid was fooling me. 65 and I STILL can't tell one from another. Even when brake fluid is so caustic.
What the $#&^%@?
Anyway, any tips on the trans shifter rod seal removal/replacement?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 07-06-2012, 11:59 PM   #2
oldspowered67C10
Re: TH350 OOzing
If I remember correctly on a th350, drop the pan, drive the pin out that holds the shift rod to the detent plate and slide the shaft out twoards the outside. Remove the old seal and drive the new one in with a appropriate sized socket. I also think there is a o-ring on the shaft, replace it also. All in all a easy job, good luck.
oldspowered67C10 is offline   Reply With Quote
Old 07-07-2012, 03:04 AM   #3
oldspowered67C10
Re: TH350 OOzing
Another note, I have changed them w/o removing the shaft from the trans by just using a deep socket but getting the old seal out is more trouble than its worth and you really should change the o-ring anyway.
Old 07-07-2012, 03:35 AM   #4
SS Tim
SS Tim's Avatar
Re: TH350 OOzing
There is a speciality tool for replacing the selector shaft seal. Just can't think of it at the moment. Mine grew legs years ago. Here take a look at post #4 http://www.hotrodders.com/forum/th35...ll-211281.html
SS Tim is offline   Reply With Quote
Old 07-07-2012, 09:12 AM   #5
asolde
asolde's Avatar
Re: TH350 OOzing
Don't drop the pan there is a seal removal tool you can get from napa part number 776-9250. Simple job.
asolde is offline   Reply With Quote
Old 07-07-2012, 09:26 AM   #6
67swb72klb
67swb72klb's Avatar
Re: TH350 OOzing
for sure you dont have to drop the pan there is a special seal tool i have removed them with a pick tool before though
that shifter seal is the same for many different trans good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 05-26-2014, 01:08 PM   #7
twouvakind
twouvakind's Avatar
Re: TH350 OOzing
NAPA 776-9250-saves you >$20 for the tool, good looking out!
twouvakind is offline   Reply With Quote
Old 05-26-2014, 05:22 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: TH350 OOzing
I use two little screws to pull them. Take an awl or tiny pin punch and poke two holes in the old seal opposite of each other. Make sure you poke the seal only and not get too close and gouge the shaft. Then screw two little screws into the holes you made and pull upwards with dikes.
Here is a TH350 I did awhile back on my stepside.
Tap the new seal in with a deep socket, a piece of conduit, or about anything that allows you to tap it in place easily.
