Old 07-06-2012, 11:54 PM   #1
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
A-arm nuts
Pulled apart a '71 3/4T front end today-it looks like the General used a white/yellow paste threadlocker on the a-arm nuts. What is everyone using when reassembling? Loctite red?
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 07-07-2012, 03:01 AM   #2
oldspowered67C10
Re: A-arm nuts
Im assuming you mean the large nuts on the ends of the cross shafts on the solid type(no bushings). No threadlocker, the shaft has to turn in the nut during suspension travel. I suppose some loc-tite between the nut and the arm itself couldnt hurt, Id use blue there but truthfully, if its torqued right shouldnt need anything.
Now, if it is the bushing type, although I thought 3/4 tons were the solid steel type, Id use red on the nuts.
oldspowered67C10 is offline   Reply With Quote
Old 07-07-2012, 10:09 AM   #3
hounddogs!
hounddogs!'s Avatar
Re: A-arm nuts
No bushings. What I was seeing was on the external thread between the nut and the arm itself.
You're thinking blue just for future removal?
DD '09 Pilot
Old 07-14-2012, 12:27 AM   #4
oldspowered67C10
Re: A-arm nuts
Yeah, red would work also.
