07-07-2012, 07:01 AM | #1 |
fire extinguisher bracket
what is the going price for a descent fire extinguisher bracket out of a '68 gmc p/u?
07-07-2012, 12:14 PM | #2 |
Hand Crafted C-10
Re: fire extinguisher bracket
Good thread! Every truck should have an extinguisher.
I can't imagine what an OEM dealer installed bracket would be worth. Can't say I've ever even seen one in real life. Quick release belt-style modern ones run less than ten bucks for the smaller size (2-ish pound) extinguishers and can be had at some hardware or farm supply stores. I know Grangers carries a good selection. If you buy the whole assembly, make sure the extinguisher has a metal, not plastic, tip. Where would you be mounting it?
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
07-07-2012, 12:42 PM | #3 |
about the best nicest extinguishers and mounting hardware i've seen have been in the marine supply stores for boats
07-07-2012, 07:42 PM | #4 |
its mounted up on pass corner near back window. my owners manual shows a list of accessories and this is one of them. came either 2 3/4 lb or 5 lb, thanx for the reply...paul
07-07-2012, 11:24 PM | #5 |
What's wrong with a plastic tip? I've killed quite a few fires (way too many) with plastic tipped extinguishers.
07-07-2012, 11:34 PM | #6 | |
The main thing is to mount it where you can actually reach it and remember where it is. I had a fire in an ot van a couple of years ago and I knew that the extinguisher was in there but couldn't find it in a panic as it was hidden under the driver's captain chair where you had to duck down and look under the seat to see it. |
