07-07-2012, 09:39 AM | #1 |
tracking arm stud removal ?
going with longer unit not mounted in stock location.
i have taken the stock tracking arm out and would like to remove the stud from the differential carrier. can this just be tapped out ? (like with a 5 lb. sledge hammer).... if so which way should i hammer... out towards the frontend ? thanks paul 66 long fleetside |
07-07-2012, 08:12 PM | #2 |
67-72 parts collector,…
Re: tracking arm stud removal ?
It "drives out",... toward the rear of the truck.
07-08-2012, 07:53 AM | #3 |
07-11-2012, 10:16 AM | #4 |
Be sure to leave the nut threaded on but loose. That sucker will shoot out like a rocket!
07-11-2012, 11:37 AM | #5 | |
do you think i am just not hitting it with a big enough hammer and with enough force ? think i will soak it with a little liquid wrench... might help. |
07-11-2012, 11:39 AM | #6 |
Use a small sledge hammer.
It's tapered,... so you are just trying to break it off the taper.
07-11-2012, 12:54 PM | #7 |
BFH.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
07-13-2012, 02:33 PM | #8 |
Grandpa in the rustmobile...
Yeah I remember something about it being funny lol soak it put a nut on it and bang on it with a brass hammer...
Listen to lolife99
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-13-2012, 03:15 PM | #9 |
Never Ending Projects
I used a air hammer with a point bit and it just popped out with no problems. Should have left the nut on as it kind of flew out... LOL
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-13-2012, 04:13 PM | #10 |
Application of a little heat goes a long way to help loosen it up too.
