Old 07-07-2012, 11:01 AM   #1
67 chevy heaven
where to purchase upper & lower bushing seals???
Ok so I tore my entire '67 front end down a couple years ago and had everything powder coated. The upper and lower control arms as well as shaft assys turned out great.However I am having much trouble locating the rubber bushing seals as well as the shaft bushing seal/boot. I can order complete shaft assys with the seals boots but I cant fine them outside of an assy.Can you please help me locate these items.
I would be most grateful!!
67 chevy heaven is offline   Reply With Quote
Old 07-07-2012, 11:53 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: where to purchase upper & lower bushing seals???
I believe www.truckandcarshop.com sells the seals separately from the shafts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-07-2012, 12:58 PM   #3
67 chevy heaven
OK I checked with truckandcarshop and they do have the rubber grommet that fits on the metal bushing.
Now is there not a rubber seal that goes on the shaft that covers the mated parts of the shaft to the metal bushing?
ClassicParts.com sells the complete shaft assy that has a rubber boot/seal as well as the rubber grommet that goes onto the metal bushing. But they dont sell them separately.
Am I right? Can some of you guys look and see if there is indeed a rubber seal/boot on the shaft, on each end, that is on the between the "A" arm.
Thanks guys I hope you can understand what I am trying to say and ask. LOL
Old 07-07-2012, 01:48 PM   #4
FLEET72
FLEET72's Avatar
You have found what your looking for, I believe they are one and the same. #7 upper, #27 lower.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 07-07-2012, 04:47 PM   #5
67 chevy heaven
Thanks guys for taking time to hold my hand through this process.
the last thing..
I found the grommets that fit onto the bushing, Now does anyone know if that is the only seal or bushing needed? I am seeing another one on a complete shaft assy from truckandcarshop.com.
