Old 07-07-2012, 01:22 PM   #1
rs72z
rs72z's Avatar
Late model seat install
I bought a set of 08 f150 8 way power seats with the console and rear seats for my cc. As most everyone knows the late model seats set way to high in our trucks. So you have three options, either use them as is and have your head almost touching the roof or remove all of the power and make some new rails..... not a option for me or lower the hump in the floor.
I went with the last option. There are a few build threads on here that shows some of the install process. I am going to take pics and try and show how i am doing the swap. is my way the right way? I don't know but it is going to work and be fairly straight foward. Any one with a welder and some skills can do it.
I started by measuring the distance from my head to the roof with the burb buckets and then with the new seats. The new seats put me 3" closer to the roof.
I made sure the truck was level side to side and the used a level on the hump and measred down 3" and marked it all the way around. I then used a sawsall and cut the hump out.
I then set the new seat in and checked the height and it was right on with the old seats.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 07-07-2012, 01:27 PM   #2
rs72z
rs72z's Avatar
Re: Late model seat install
Showing my cut marks.
___________________
78 ccsb dually
5.3
4l60e
Old 07-07-2012, 01:30 PM   #3
rs72z
rs72z's Avatar
Hump cut out, new seat setting in and the 16 gauge sheet metal replacement.
More later have to go now.
___________________
78 ccsb dually
5.3
4l60e
Old 07-07-2012, 06:47 PM   #4
v30crewcab
v30crewcab's Avatar
what do you plan on doing about carpet? thats my only hangup with doing that I guess. looks good so far though.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-07-2012, 07:08 PM   #5
rs72z
rs72z's Avatar
Been thinking about that. I will cross that bridge when I get there. My brother has a upholstery sewing machine, might be able to cut it to fit and sew it back.
___________________
78 ccsb dually
5.3
4l60e
Old 07-07-2012, 11:34 PM   #6
rs72z
rs72z's Avatar
more pics
___________________
78 ccsb dually
5.3
4l60e
Old 07-07-2012, 11:38 PM   #7
rs72z
rs72z's Avatar
more
___________________
78 ccsb dually
5.3
4l60e
Old 07-08-2012, 12:12 AM   #8
68Timber
I know the pieces fit
68Timber's Avatar
Good job taking what you wanted and making it work.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-08-2012, 08:31 PM   #9
rs72z
rs72z's Avatar
___________________
78 ccsb dually
5.3
4l60e
Old 07-09-2012, 12:01 AM   #10
legendman
legendman's Avatar
All that work to put a set of ferd seats in a chevy... somethings wrong here
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 07-09-2012, 07:38 AM   #11
rs72z
rs72z's Avatar
I like to drive my truck and want to be comfortable doing it. I would be doing the same work to install late Chevy seats! Besides i only give 100 bucks for all of it.
___________________
78 ccsb dually
5.3
4l60e
Old 07-11-2012, 12:28 PM   #12
rs72z
rs72z's Avatar
I got the passenger side all cut out and the new piece made to go in it. More pics this weekend.
___________________
78 ccsb dually
5.3
4l60e
Old 07-11-2012, 01:02 PM   #13
Firebirdjones
WOW, that's alot of surgery to install a newer seat. I think my factory bench is just fine and plenty comfy
I'd cringe at the thought of cutting up my rust free truck after all the trouble I went through to find/buy it.
Isn't there a way to modify seat tracks instead to keep the modifications to the seats only rather than cutting the truck? At this point there is no turning back since this isn't exactly a reversable mod for most people.
Firebirdjones is offline   Reply With Quote
Old 07-11-2012, 01:43 PM   #14
rs72z
rs72z's Avatar
There's no way to modify the tracks and still retain all the power functions.
It's what ever your happy with. I wasn't happy with the burb buckets that i had and i have never liked the bench seat in the squares. I have no problem cutting the floor to get the comfort and adjustiblity of late model seats.
When done i will have about 8 hours in the front install and then i have to figure out the rear.
___________________
78 ccsb dually
5.3
4l60e
Old 07-11-2012, 02:20 PM   #15
Stepper86
Stepper86's Avatar
Nice truck!
Is the base going to be sturdy enough with a straight plate or is the plan to add some support for it? The original hump has pressings in it to keep it stiff. Im just woundering since those seats with all the comfy functions built in must be heavier than original buckets?
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 07-11-2012, 02:38 PM   #16
rs72z
rs72z's Avatar
I am going to weld a flat strap across each side where the seats will bolt up at. I should have rolled some beads in the plates but i didn't have the roller at my shop. It should be good the plates where the seats bolt at are at the very front and the very back, and sitting in it i dont feel any movement.
___________________
78 ccsb dually
5.3
4l60e
Old 07-11-2012, 02:46 PM   #17
Jeepwm69
So you had burb seats from an 88-98 series truck. Will a seat from 95-98 fit without modifications? (I'd like to get a stock bench seat from a 95-98 that has the fold down armrest)
Looks good on the leather. As far as using a Ford seat, my AMC made Jeeps were basically Frankenvehicles with all the different stuff they used to build them. Had Ford ignition, carbs, GM steering columns, etc.
Jeepwm69 is offline   Reply With Quote
Old 07-11-2012, 03:07 PM   #18
rs72z
rs72z's Avatar
The burb seats were from a 91 square body burb.
The 95-98 bench sit will work because you can change the rails on them.
___________________
78 ccsb dually
5.3
4l60e
Old 07-11-2012, 04:48 PM   #19
dmartin1
dmartin1's Avatar
yeeeow! thats a lotta carnage for some seats.
i wanted some power seats for my k20 but definately didnt wanna go that far i just searched for some that i could modify the tracks etc on and mount on the original floor.
good work though bet those will be comfy!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 07-11-2012, 05:02 PM   #20
rs72z
rs72z's Avatar
Yea it's alot of work but it will worth it. I have lower back trouble and just cant ride in the old seats very far. I built my truck to drive and that's what i plan on doing.
___________________
78 ccsb dually
5.3
4l60e
Old 07-12-2012, 10:10 AM   #21
crewcabsquared
RS, I like what you are doing. I too enjoy a good set of seats on something I drive alot. The surgery on the pans doesnt bother me at all, nothing you've done couldnt be put back to original easily. Enjoy them comfy seats!!!
crewcabsquared is offline   Reply With Quote
Old 07-12-2012, 11:39 AM   #22
82ccshorty
82ccshorty's Avatar
Are you going to keep the old buckets?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 07-12-2012, 11:42 AM   #23
rs72z
rs72z's Avatar
Thanks. Looking foward to getting it done.
___________________
78 ccsb dually
5.3
4l60e
Old 07-12-2012, 11:43 AM   #24
rs72z
rs72z's Avatar
Gonna get rid of them.
___________________
78 ccsb dually
5.3
4l60e
Old 07-12-2012, 11:45 AM   #25
82ccshorty
82ccshorty's Avatar
i sent you a pm.
