Old 07-07-2012, 05:24 PM   #1
sox8145
6'' flip kit
What's up guys I have a little problem with my flip kit I installed it every thing went fine but when I put it back on the ground I didn't like the drop it gave it my wheels pass the wheel wells about 1/2 inch making the back look way lower then the front which is a 4 inch drop any one else have this problem if so what can I do to fix it I'll try to post some pics to show u
sox8145 is offline   Reply With Quote
Old 07-07-2012, 05:43 PM   #2
bbbc10
Diggin The SquareLife
Re: 6'' flip kit
mine is 5/6 an my front is an 1" lower than rear....did ur truck have shackles or hangers on it already??? cause 4/6 drop makes it sit level
bbbc10 is offline   Reply With Quote
Old 07-07-2012, 06:42 PM   #3
sox8145
Re: 6'' flip kit
here r sum pics the top is before the drop the bottom is after
Old 07-07-2012, 06:45 PM   #4
sox8145
Re: 6'' flip kit
Im not to sure if it did have shackles it was an old farm truck before i got it and who knows before that im thinking the leaf springs r wore out not sure tho
Old 07-07-2012, 07:13 PM   #5
J Knight
J Knight's Avatar
Re: 6'' flip kit
The front looks more like a 3in drop, check to see if your coils are installed properly. To see if you have drop shackles look above the shackle to see if the bed brace is notched and also see how many leafs you have. Typically you should have 4(3 thin and 1 thick). If you have less than that someone removed a leaf to lower it at some point.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-07-2012, 07:20 PM   #6
bigwheel15
bigwheel15's Avatar
Re: 6'' flip kit
Make sure your springs are seated properly, and possibly give them time to settle if they are new drop springs.
bigwheel15 is offline   Reply With Quote
Old 07-07-2012, 07:38 PM   #7
superwade57
Re: 6'' flip kit
being an old farm truck its very very possible the rear springs are wore out... farmers are known to use abuse and over load trucks almost regularly
superwade57 is offline   Reply With Quote
Old 07-07-2012, 07:46 PM   #8
gGMC DOG
Re: 6'' flip kit
the heavy duty leaf pack will yield more drop in the rear because the thickness of the leaf pack.
gGMC DOG is offline   Reply With Quote
Old 07-07-2012, 07:50 PM   #9
gGMC DOG
Re: 6'' flip kit
bed brace does not have to be notched if it's on the longer leaf pack
Old 07-07-2012, 08:14 PM   #10
gGMC DOG
Re: 6'' flip kit
link will allow you to see the differences in spring setups for our trucks that were stock
http://www.generalspringkc.com/Leaf_...987_s/1823.htm
Old 07-07-2012, 08:16 PM   #11
sox8145
Re: 6'' flip kit
cool ill look at that tomorrow my truck is in the shop all stripped down and getting ready for paint and the kit i got was a belltech 4/6 with of couse flip kit and 3'' spindle and 1'' springs and it also came with the drop shocks
