Yet another header questions for my 71
I've been searching and looking at post about headers for hours now. I've looked so much I've confused myself.
I have a 71 C10 with a 350 5.7 motor with a 350 turbo transmission that was manual but now has a shift kit installed. I'm bagging the front of my truck and need to know which shorty header will work with my truck without having to modify anything. I need part numbers of headers that have worked for you guys straight out the box and don't interfear with anything else on the truck. I'm planning on running my exhaust pipe outside the frame just above the frame bottom. Any help would be appreciated. I need to order my headers ASAP so I can finish my exhaust system. Thanks |
![]() Join Date: Oct 2004
Re: Yet another header questions for my 71
X2
I have been using the Sanderson Shorty headers since December. My truck has 350/th400 and lays frame...pic in my signature.
Get them from Summit for under $300 Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
PS - do yourself a favor and get the following, shorty headers especially need this:
-header spark plugs (they have a shorter base/top, but are made for performance and they sell them by application, i.e. 350ci engine -get a spark plug wire loom that will route the wires away from the tubes on the headers, and keep the boots stationary...trust me, it will save you $$$ in the long run in buying wires every month Advance Auto sells the plugs, Summit has a great loom that bolts to valve covers. I went a step further and got the braided spark plug wires....doing great so far. Posted via Mobile Device
Just ordered a set of Hooker headers. 2466HKR. I will let you know how they fit after I install them.
Young gun
did you ever install these? if so how do you like the fit? thanks
67 SWB Custom "JANE" http://67-72chevytrucks.com/vboard/s...d.php?t=554024 Northwest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ Cameron sparks |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#9 | |
Young gun
The fit was great. However it was a little close to the motor mount on the drivers side for some reason. I'm not sure why cause it wasn't close on the pass side. Probably was how my engine was mounted.
Sorry, missed the question. I know...much later
#12 | |
Young gun
#13 |
hedman headers #69010. Shorties made specifically for these trucks. Mine fit great. Jegs has them for around $200. Then use NGK UR5 plugs. short enough to clear, not expensive like header plugs, and last a LOT longer.
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#14 |
Cubber, you have pics of them installed?
#15 |
Sent you a PM. Gonna have to get pics tomorrow.
#16 |
#17 |
Cubber thanks for the pics!
I just ordered a set from Jeggs and they have them for $161.99, $20 off!! |
#18 |
Cool! Glad I could help!
