![]() Join Date: Oct 2008
Frame Dimensions
I have a 69 1/2 ton 4x4, and the frame from the bed back is pretty pitted. It's not rotted all the way through but it can't be very strong. Are the frame rails from a 73-87 frame the same size (height, width) I was thinking I could just cut the pitted sections out and weld in pieces from a doner frame and brace it good. 67-72 4x4 frames are hard to come by in New York that aren't rotten.
Thanks,Marty
My Chevys 79 caprice classic 70 c/10 69 k/10 03 silverado |
#2 | |
Re: Frame Dimensions
Check craigslist, I see 4x4 frames on there time to time. I live in kansas city and i've seen them on there for $200 i think. if you need a new one.
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
Thanks guys I'll have to keep my eye out for one, I was hopeing for a cheaper easier route, 4x4 frames are hard to come by in the rust belt, we turned them all into plow trucks and destroyed them.
Would a 2wd frame work since he just needs the back half of a frame?
I'm pretty sure the 2wd frames bump out above the rear axle while the 4wd frame stays straight. Not sure though maybe someone can confirm? Thanks for the suggestion though, if they are the same, that saves a lot of looking.
the '72 2wd frame is much different in the rear axle area than the 4x4 frames. i'd assume the '69s are different also. it is difficult to adapt spring hangars to the front end of the rear springs on the 2wd frame because it kicks out at about 5* and up at 24* right where the spring hangars need to mount.
