Old 07-08-2012, 11:28 AM   #1
texastrendz
Dropmember radiator setup?
I was looking for some feedback on a radiator setup. I was wondering if anyone was running a factory 4 core radiator with a dropmember. The other factor is that this truck is running an ls based motor with a mechanical fan. I would like to keep the fan if possible, but not opposed to running electrical fans. IF possisble I would also like to know if you can run the factory fan shroud. I know it is a lot, just wandering if anyone has tried it. My truck is totally in pieces still and I want to start collecting the right parts. Thanks again , Daniel.
texastrendz is offline   Reply With Quote
Old 07-12-2012, 12:25 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Dropmember radiator setup?
Anyone,...?
Keith
Convert to disc brakes.
Old 07-12-2012, 06:19 PM   #3
GVizzle
GVizzle's Avatar
Everyone I seen running an Extreme drop member scrapped the mechanical fan and went to electrics due to clearance issues.
I went with this in OLD AUX as recommended by N2Billet. He's got some good photos and ideas in his build thread.
Entropy builds radiators for LS also.
Below are two good links. Happy reading.
http://67-72chevytrucks.com/vboard/s...d.php?t=351837
http://www.entropyrad.com/Radiators/...r/prod_14.html
GVizzle is offline   Reply With Quote
Old 07-13-2012, 12:35 PM   #4
n2billet
Village Idiot....
n2billet's Avatar
Also when using a DropMember keep in mind that the motor is raised about 3 inches (not sure about the LS motors) so if you us a mech. fan it will not be centered in the radiator.
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 07-14-2012, 10:32 AM   #5
67cheby
67cheby
67cheby's Avatar
i am running the 4 core with electric fan set up and the bolt on body drop
67cheby is offline   Reply With Quote
Old 07-15-2012, 11:56 AM   #6
texastrendz
I would like to run a factory four core rad if possible, I need to go and look in your build thread to see what you did.
