Old 07-08-2012, 03:11 PM   #1
Blue666
Angry Exhaust Manifold Stud Removal
Ok, I found a nice pair of ram's horn manifolds with a y-pipe and a heat riser. The y-pipe nuts came right off but the studs are rusted with threads missing.
I have been soaking the studs with nut buster every few nights, trying to turn the studs either forward or back to start some movement. I have heated studs & manifold ears but the studs are still stuck.
Do I just grind off the studs & drill & tap the holes? Does anyone have any sure fire, never fail tricks to get these out?
Blue666 is offline   Reply With Quote
Old 07-08-2012, 03:33 PM   #2
El Campo
El Campo's Avatar
Re: Exhaust Manifold Stud Removal
Iv never had a bolt that a torch wouldn't fix. Sometimes you have to heat it several times but it will get even the rustiest bolt out. Maybe heat it up hotter? Hate doing it on things that need a straight edge but I heated up a I6 manifold stud red hot one time and it didn't cause a problem. It is super hard drilling out a bolt and getting it centered even with a drill press it is difficult.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-08-2012, 04:16 PM   #3
62 Barnfind
62 Barnfind's Avatar
Cut them off and drill and re-tap. They will break anyway and you will still have to drill and tap. I replaced mine the same way.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 07-08-2012, 04:54 PM   #4
rideblue00
rideblue00's Avatar
Heat it with a torch. I did that with mine, all 6 studs came out with no problems.
rideblue00 is offline   Reply With Quote
Old 07-08-2012, 05:16 PM   #5
purebred
I agree with the heat, heat it until cherry red, wait a little bit and they will come out. Slowly
purebred is offline   Reply With Quote
Old 07-08-2012, 05:31 PM   #6
aerotruk63
aerotruk63's Avatar
Once you get them out, or drill and tap, you might have to Heli-Coil the manifold.
Old 07-08-2012, 05:34 PM   #7
Indian113
Indian113's Avatar
The trick is to let it cool down to touchable before putting any torque on the bolt. I have sprayed penetrating oil on the bolt as it cooled can't say it helped but didn't hurt.
Indian113 is offline   Reply With Quote
Old 07-08-2012, 05:38 PM   #8
sigshooter
sigshooter's Avatar
Candlewax
Heat the stud and manifold area, drip candlewax ( from an ordinary candle ) right onto the threaded area of the stud-manifold ( just like the rust buster you were using ). this will melt down into the threads and provide a nice lubricant when you go to remove the studs..... wont burn up like most wd40 type stuff does
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 07-08-2012, 09:51 PM   #9
bama63
bama63's Avatar
x2 on the candle wax trick, works great
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
