Old 07-08-2012, 03:21 PM   #1
dstarrett
dstarrett's Avatar
keeping gas in the carb
How do you guys keep the carb full of fuel when sitting for extended periods? Is there a better way to reintroduce fuel on a restart other than squirting in carb? Rebuilt 283 with edelbrock.
dstarrett is offline   Reply With Quote
Old 07-08-2012, 08:52 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: keeping gas in the carb
You could back it up with an electric pump with a switch, turn on to fill then turn it off when done.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-08-2012, 08:52 PM   #3
fleetman
if its evaporating out of the carb i dont think much can be done about that.
but i had a problem like this. the see thru-in-line gas filter that is near thecarb would not stay full. gas would leak back when the engine was off.
what it was was cheap snap on hose clamps did not make a air tight seal. after putting 4 screw clamps on the fuel hoses.... no more leak back and the filter stays full of fuel.
hth
fleetman is offline   Reply With Quote
Old 07-09-2012, 01:51 PM   #4
fleetman
question..... how much pressure is safe for electric fuel pump ?
thanks
Old 07-09-2012, 03:42 PM   #5
Rich 5150 69
3-5 lbs,
Old 07-09-2012, 03:59 PM   #6
tincan1966
tincan1966's Avatar
I just install an inline fuel filter with a check valve on the frame before the fuel pump inlet. That way the fuel pump stays full also.
tincan1966 is offline   Reply With Quote
Old 07-09-2012, 04:13 PM   #7
fleetman
great practice. going todo this. thanks
